Valve cover gaskets
Valve cover gaskets
Seems like this car and coolant dont mix well. Today I started the car up in the morning and ran it for a minute or two while I was changing parking positions. I looked under the car for leaks and found some coolant dripping under the pass side head. It appeared to be coming from the little triagular shaped plastic thing with a round hole twords the narrow end, splash guard or something. Anways I looked around and found it was dripping from the valve cover gasket. How it got there I don't know but I thought oil was the only thing that flowed through the valve covers. So does anyone have an idea of what the problem could be? Just the gaskets or something more?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Looking at the engine in my kitchen, I can't see how you'd be getting coolant from there unless you had a very strangely cracked head. Is it dripping from the radiator to upper water pipe hose and travelling down the valve cover? It's the only way I can imagine you'd be getting coolant dripping there. A cracked radiator or bad drain plug on the radiator could cause dripping on the splash guard, too, but I don't see how it would get to the valvecover. Could it be from the headgasket maybe and looks like its coming from the valve cover somehow?
I didn't really check the upper hose though that should've been the first thing to check. I only looked at the top not the bottom. It had better not be a blown hg already, only been in there 2 days. I'll be looking at it tomorrow and see if it shows up again.
I had suspected that but I searched the whole area and there was no coolant coming from the radiator at all, it started about midway on the triangle, the coolant that is.
I don't see anything today, so idunno.
- quasi-mod-o
eastbaysubaru
PERFORMANCESUBE
VALVE COVERS
If your valve cover gaskets were leaking, you'd see oil on either side of the engine....where the covers meet the block...
Jessica
Jessica
**'92 LEGACY TURBO WAGON IN RED**
**'92 LEGACY MUTANT L SEDAN IN WINESTONE**
___SPEED KILLS!!! DRIVE A FORD AND LIVE FOREVER____
PERFORMANCESUBE
YEAH...
yes, hun, the head
Jessica
Jessica
