vent control buttons
jlb
Post by jlb »
Any one have a stuck in on position defroster vent control button? How do I fix ? Right now only the defrost vents will blow.
Re: vent control buttons
You have to get under the dash and mess with the gears and arms that control the vent. They're either binded or need grease or your motor is dead.
mjc1310
Post by mjc1310 »
I am actually diving into thethe same problem tomorrow. Will let
you know what I find out.
The solder joints on the HVAC controller are probably cracked. Check out this thread.
http://bbs.legacycentral.org/viewtopic.php?f=10&t=1142
mjc1310
Post by mjc1310 »
I did perform the above recommendation. I soldered the contacts that looked cracked or had hairline cracks under a magnifying glass. Put most of the dash back together and no luck. So I laid under the steering wheel while changing buttons and heard my motor try to switch and would sloowwwlly wind down. It is most likely one of the two issues in your case.
