Hey guys,
I am installing an ACT Prolite for a 02-05 WRX with an Exedy OEM WRX clutch kit.
I see that the WRX bolts (P/N 800610740) are 10X24.5X17
I see that the SS bolts (P/N 800210660) are 10X27.5x20
What I think I am seeing here is that SS bolts have a different thread pitch, so I have to use them... but they are also longer by 3mm. Can I get away with this or am I going to have problems?
I've done some homework here and NASIOC, nothing conclusive.
Bolts for WRX Flywheel/Clutch into SS
Re: Bolts for WRX Flywheel/Clutch into SS
I wasn't aware of a difference. I'm using wrx bolts on mine since I'm using a wrx flywheel, wrx pressure plate and disc. Fits perfect.
I used SS Bolts on my wrx exedy oem replacement with an F1 racing flywheel.
Yeah, you should be fine.
I ended up ordering both from subarugenuineparts. The SS bolts were only ~$3 for all 8.
When I do the job I'll post up any differences between the bolts.
Thanks for the help guys!
