Hey guys. I was wondering if any of you knew of a good site to get a stock bypass valve. I have an sti intercooler that is going on my 2.2T and need the bypass valve.
Thx
Bypass Valve
Naked Buell
Bypass Valve
86 Brat, 2.2T, AWD, TD04, Intercooled,
88 Rx, Future EJ upgrade soon
Re: Bypass Valve
Re: Bypass Valve
Hi,
SS/TW or something else?
That STi IC won't fit your SS...unless you have a BFH to massage your firewall - a lot...search on here to double-check.
You need a stock SS BPV or the STi BPV? That will also be a challenge to make work on the SS as the throttle body setup is different and the STi was DBW. Most (all?) use the adapter plate and run a hose back to the intake and use the SS BPV.
FWIW, the '06-07 WRX and '06-08 FXT BPV will also work.
GL,
Td
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Naked Buell
Re: Bypass Valve
The 2.2T is in my Brat. I have upgraded to a TD04 and have added a sti aftermarket intercooler. I have the stock SS bypass valve and I can use that? If so, is there any pics so I can understand better what you mean about this adapter plate?
I am fuzzing about what hooks up where so any info and pics would be great. Thx
Re: Bypass Valve
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
