EJ22T Rebuild Time
Re: EJ22T Rebuild Time
I did not have my block halves machined when I did my cometics, they lasted me 3 years.
mike-tracy wrote:No personal experience but my machinist said you have to have a perfectly machined surface on the block and heads.
That's pretty much what I've heard as well.
92legacyawdturbo
Post by 92legacyawdturbo »
Sorry been a few but got time to write today haha. Anyways either using Ridgereamer in Arvada as i know quite a few who have gone there or my buddy works at suba pros knows a few ppl as well with good work. i got a lot of stuff in and suppose I could get some pictures up.
1992 Awd Legacy Turbo Sedan
macipusy
Post by macipusy »
I used Ridgereamer to deck my block for the ej236t build. The surface of the block was not smooth at all. It was a swirly rough pattern...perfect for the composite stock ej22t HG. There might be some pictures of the surface in my build thread.
I did not specify a finish when I dropped it off. Just followed their recommendation.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
92legacyawdturbo
Yea will have to check cause few friends did theres at Ridgereamer and was perfect so smooth.
92legacyawdturbo
Also curious I have the option of ej20g heads good condition that should just slap right on as well. Should I go that route cause time is getting kinda hard and need to get this motor done to have a vehicle once again. Also if so on the ej20g heads what price would they go for normally? Thanks
I think you can get a set with intake manifold for about 300 bucks.
92legacyawdturbo
Well my buddy has the heads and mani but I dont want to cut him short of money cause not like me so rather get a fair price for him on it as I would feel better. So knowing a price helps me out.
92legacyawdturbo
Curious as what I need for a flywheel since need a new one, see a Pioneer Flywheel for my generation is available as well since its stock. Also going with Competition Clutch Stage 2 Steelback Brass Plus Clutch Kit .Just fyi will be running higher boost about 21lbs to try and get closer to the 300 hp mark. Thanks
92legacyawdturbo
Another thing confused on as have been reading this article: http://bbs.legacycentral.org/viewtopic.php?t=38247
I am going with EJ20G heads and manifold and trying to figure out what I need all in all. Like will EJ22T head gaskets work on the motor, also for manifold would ej22t gaskets work or need different ones from wrx 2.0. Would appreciate some more answers on this. Thanks
If you have a turbo legacy MT or another "pull" style clutch transmission, you can use a turbo legacy flywheel or a 2002 - 2005 WRX (pull style clutch) flywheel. If you go with a WRX flywheel you should also use a WRX pressure plate & clutch.
92legacyawdturbo
So another question which I am full of. Looking for the power steering return and pressure from the rack cant seem to find them, if you got part numbers or where I can get them would be great. Cant find them from the Subaru dealer. Thanks
Are you wanting the part #'s for the stock turbo legacy power steering lines?
If so, have you downloaded the parts book in this thread and looked in there?
http://bbs.legacycentral.org/viewtopic.php?t=30531
92legacyawdturbo
Yes Josh, looking for stock part numbers so I can figure out how to replace them as want new if I can get them. I will have to look in that after work tomorrow unless your so kind to post them for me. I did download the manual so need to check it out also. Thanks. Also I am trying to find EJ20G valve cover gaskets and what not and based on what I been reading people say a 96 Legacy GT will fit, can you confirm this if so would like to order them.
92legacyawdturbo
Here are some pics I have meaning to upload. I dont have pics of the heads I am using yet as they are at the macine shop but here are a few pics in general. Teardown of some and new parts.
92legacyawdturbo wrote:Yes Josh, looking for stock part numbers so I can figure out how to replace them as want new if I can get them. I will have to look in that after work tomorrow unless your so kind to post them for me. I did download the manual so need to check it out also. Thanks. Also I am trying to find EJ20G valve cover gaskets and what not and based on what I been reading people say a 96 Legacy GT will fit, can you confirm this if so would like to order them.
Sorry I'm just replying now, this week has been pretty ridiculous. If you still need the numbers, it'll be tomorrow befor I can look through the parts book.
Regarding the valve cover gaskets, have you looked at this thread in the sticky compilation thread?
http://bbs.legacycentral.org/viewtopic.php?f=5&t=44879
92legacyawdturbo wrote: Image
What is that in the picture that's bolted to the block?
I can confirm that if you have the impreza ej20g heads, the 1996 Legacy GT valvecover gaskets will fit.
If you have the old legacy ej20g heads, you'll have to source them from overseas as we didn't get anything with that style gaskets.
92legacyawdturbo
Josh, in that picture is a torque plate, used to machine the block so it stays round and in shape basically what I have been told. Keeps the cylinder in its shape so when you bore it out it does not change the diameter like taking it out of its roundness. My buddy at his shop recommended them as he does motors and motor builds all day and has seen some negative impacts when those were not used. Also I did source the power steering lines needed so appreciate that as well. Mike-tracy thanks on that info I will need to check it out and double check for the valve cover gaskets. I am waiting by either tomorrow or early next week for the machine shop to be done with the motor and then I can reassemble everything and get it going.
Ok, thanks for the info!
92legacyawdturbo
So some more pics of motor back:
I love the look of freshly machined engines!
mike-tracy wrote:I love the look of freshly machined engines!
"Like"
CAV3MAN227
Post by CAV3MAN227 »
-Cant wait to get this running.
-Joe
92legacyawdturbo
More to the build:
