Joe's 93 RHD Legacy Wagon Build
Sublimejoe
Post by Sublimejoe »
1993 Subaru Legacy Wagon. Original RHD Postal Wagon
- Current Motor:
- 98 Ej22
- Drivetrain:
- 5spd Manual Conversion (Thanks Rouf!)
- JDM WRX Turbo Crossmember (Thanks to Jspec in Richmond, VA, Paul who picked it up, Alex who met up with Pau,l then brought to my garage!!)
- JDM WRX Steering Rack (Thanks to Jspec in Richmond, VA^^^)
- Custom Steering Knuckle (Thanks to my friend for taking time away from making grenades to make this for me!)
- Exedy OEM Clutch & Flywheel
- Kartboy Shifter Bushings
- Hydraulic Clutch Conversion
- GC8 WRX Master Cylinder
- Chase Bays custom RHD specific clutch line (Thanks to Chase and Johnathan at Chase Bays)
- Exterior:
- Full Respray including bay and jambs (NH-0 Championship White) Paint by Herlihy Fabrication in Winchester, VA
- Ausdm Power Folding Mirrors
- Ausdm Grill (Thanks Jake Duck!)
- Ausdm rear tailgate garnish (Thanks John Wayryen!)
- Ausdm tail lights (Thanks John Wayryen!)
- Fresh OEM molding all around
- Refinished window molding sourced from parts car! (Thanks Jim Kelly!)
- Interior:
- JDM Momo Steering Wheel from 93 Legacy
- Door cards dyed to match steering wheel
- Black Alcantara wrapped armrest by @mikeyseats
- Suspension:
- Cheap Coilovers (To go air or nice coils?)
- GC8 STI Carbon front strut tower bar (Thanks to JEI in Manassas, VA)
- Wheels:
- Rays TE37 16x8"
- Advan RG 17x7.5" +48 (Thanks to the most @RadBlackDad I know)
- Pirelli Dragon 215/45/zr17
- Brakes:
- 2005 Legacy GT Calipers & Rotors (Thanks Shawn!)
STILL NEED! PLEASE HELP!
- Rear Wagon Spoiler (OEM or Aftermarket)
- Front Lip (OEM or Aftermarket)
PICTURES!
BEFORE:
Progress:
Reserved for picture dumping!
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
Re: Joe's 93 RHD Legacy Wagon Build
Nice. Looks way better. Love the outback. Those wheels are sick.
If you want a cleaner look bake the tail lights at 150-200 degrees in the over for a few minutes and remove the lenses and pull out the orange turn signal lenses. Bake again and reinstall lenses. Keep a close eye though. I warped a set bad my first try. Second set came out great.
Sublimejoe
kimokalihi wrote:Nice. Looks way better. Love the outback. Those wheels are sick.
Thanks!
kimokalihi wrote:If you want a cleaner look bake the tail lights at 150-200 degrees in the over for a few minutes and remove the lenses and pull out the orange turn signal lenses. Bake again and reinstall lenses. Keep a close eye though. I warped a set bad my first try. Second set came out great.
Thanks, I will do that! I was wondering if the amber lenses would come out easily.
Parts Needed:
Manual Cluster
Replace the bulbs with some yellow bulbs too.
Post by SILINC3R »
I hvae a GT, but I do love the Outback XTs. They look more aggressive with the flares and I love the front bumper
What wheels are those? I'm too chicken to try some exotic wheels but I've seen quite a few on subarus lately that look fantastic.
Sublimejoe
kimokalihi wrote:What wheels are those? I'm too chicken to try some exotic wheels but I've seen quite a few on subarus lately that look fantastic.
Thanks! They are Rotiform VCE's
Parts Needed:
Manual Cluster
Jeffbugeyewrx
Post by Jeffbugeyewrx »
I think you were interested in buying my Legacy at one point half a year back. http://24.media.tumblr.com/59691a77302b ... 1_1280.jpg
Looks great by the way!
Sublimejoe
Jeffbugeyewrx wrote:I think you were interested in buying my Legacy at one point half a year back. http://24.media.tumblr.com/59691a77302b ... 1_1280.jpg
Oh yeah! I think you know my friend Jay Stacey.
Parts Needed:
Manual Cluster
subaru_styles
Post by subaru_styles »
looking good!
1994 SS "JDM-OEM"
1992 rhd BF5 gt
Jeffbugeyewrx
Yeah! She was the one who kept telling me about your car! Looks great and glad you found one!
Sublimejoe
I found a motor! A local guy is selling an EJ22 longblock for dirt cheap. I am going to pick it up this week and more than likely rebuild it before I swap it into the car.
Next step is finding all the rebuild parts I will need.
Parts Needed:
Manual Cluster
Hey Joe, is it true that the postal wagons come with manual seatbelts from the factory? I notice you have them.
Sublimejoe
Yes sir. Do the non postal versions have electric seatbelts?
Parts Needed:
Manual Cluster
Unfortunately so. Many are malfunctioning at this stage, and mine never felt like they were going to stop me in case of an accident...
Sublimejoe
Sublimejoe wrote:I found a motor! A local guy is selling an EJ22 longblock for dirt cheap. I am going to pick it up this week and more than likely rebuild it before I swap it into the car.
Here it is:
Does anyone here know what is required to turbo this motor? I.E. can I use some ej22t parts to make it happen?
Parts Needed:
Manual Cluster
Sublimejoe wrote:Does anyone here know what is required to turbo this motor? I.E. can I use some ej22t parts to make it happen?
It's a little more complicated than just throwing some ej22t parts in it. You can run different pistons which would lower the compression. The non-turbo cams has more valve overlap than the turbo cams which can cause poor or limit performance at higher boost. The exhaust is different, front sub frame, wiring for the boost related sensors, and the ECU.
If you really want to go turbo, I'd suggest doing some searching and reading of threads for those that have done turbo swaps. If you really want to do a turbo motor, I'd suggest just starting with a turbo motor, ej22t or ej20g.
Sublimejoe
Ahh, I see. I suppose I will just keep it N/A and have fun with the cosmetic side of things instead of going for a power build.
Another question, can anyone help me out by letting me know what I would need to completely rebuild the heads? I don't need part numbers or prices (although I will create a chart for others once I do that research,) more just a list of everything needed.
Parts Needed:
Manual Cluster
Sublimejoe
I made this spreadsheet for parts I need to rebuild the heads. Does this look right to everyone?
Parts Needed:
Manual Cluster
That looks about right to rebuild the heads.
czei
Post by czei »
What does baking them do?
Baking them heats and softens the adhesive so you can separate the lens from the housing.
Sublimejoe
The car goes to the body shop tomorrow to have the remainder of repairs done before paint time!
Parts Needed:
Manual Cluster
Sublimejoe
I finalllllllly got my replacement motor to my house last night and had a chance to look at it. I got a ton of parts included which is super rad! Now I just want to try and figure out what year this motor is from and any other info. I looked all over the block and took photos of anything I thought may help, so onto the photos:
On the bellhousing:
Thank you so much in advance!!
Parts Needed:
Manual Cluster
