How to fix your sunroof!
Post by SILINC3R »
Well after 8 years of owning a first gen I finally have a fully functioning sunroof. I just got off from work and didn't take any pictures but my old 90 LS has issues also so I will use that one for pictures.
I understand this thread is useless right now without a write up or pictures but I will update when I get the chance.
However, if you have questions feel free to ask and I should be able to answer them.
ride_child
Re: How to fix your sunroof!
Post by ride_child »
its a pain in the ass but soo worth it huh?!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
just-rust
Post by just-rust »
Mine leaked when I bought it. I lucked out as all I needed to do was recondition the stripping on the exterior seal and I didn't have any problems after that. Luckily no hose shrinkage or compromised seals. I was not looking forward to pulling everything out and resealing it!
Rusty 1991 EJ22T - VF28 - '07 wrx TMIC - MBC - Invidia DP - Walbro 255 SOLD
1992 Legacy SS 5mt, with some neat stuff on it
Mine leaks. Guy who sold me the whole assembly resealed it but did a poor job. I've always wondered if I could buy a new rubber seal for the glass and achieve a better seal and not need to pull it apart and reseal it again.
How did you recondition your seal? I once read that Nissan sells a product that does just that.
just-rust
Post by just-rust »
My dad had some stuff that he brought over. I can find out what it was. I just applied it a few times throughout the day and it has been sealed since.
I brought it through a car wash after I had bought it and found out why they had it stored under a tarp. lol
Tony,
Out of curiosity, did you see/follow this thread in the sticky compilation?
http://bbs.legacycentral.org/viewtopic.php?f=10&t=183
Post by SILINC3R »
It did see and wanted to update. Mine wasn't leaking though, well it was but fixed that too. Didn't realize that was a sticky. I'll have to read all the pages and see what else was in there. Once i get ahold of the other car you'll see how comprehensive my repair was.
Raquon
Post by Raquon »
This thread is funny since I used mine the first time yesterday, worked twice then got stuck!
Post by SILINC3R »
Raquon wrote:This thread is funny since I used mine the first time yesterday, worked twice then got stuck!
can you operate it manually?
Raquon
Post by Raquon »
Post by SILINC3R »
If it isn't clicking might need to replace the relay behind the dash.
turbo970
Post by turbo970 »
where behind the dash is the relay
Post by SILINC3R »
Look in the haynes if you have it. But it is on the left side behind the vent kind of. You can reach it if it has been messed with before. Otherwise it will still be connected to its bracket.
turbo970
Post by turbo970 »
o ok cuz mine i have to thump the ceiling when it sticks
Nibbib
Post by Nibbib »
i believe my relay is bad motor makes no sounds but did work ones in a very rare blue moon
whats the best way to test the relay
Post by SILINC3R »
Switch in another relay
Nibbib
Post by Nibbib »
I'm asuming just go to my local pick n pull and get one?
Post by SILINC3R »
Yes, that is whwt I would do. Then you can grab a couple of them.
Nibbib
Post by Nibbib »
a local subaru shop has a bunch for 10 bucks and they test all of them and only keep the good ones so im getting one tuesday and replace mine hopefully it will be fixed lol.
and im also redoing my headliner with black fabric.
Raquon
Post by Raquon »
I need one haha!
Post by SILINC3R »
Nibbib wrote:a local subaru shop has a bunch for 10 bucks and they test all of them and only keep the good ones so im getting one tuesday and replace mine hopefully it will be fixed lol.
That's awesome. Now once you get the relay you can plug it in. If then when you use the switch and you hear the relay click listen for the motor. If the motor tries to move but nothing happens then the cables are siezed and we can mvoe to the next step. If the motor does nothing double check the connector at the driver drain and check that the motor is grounded and the motor plug is getting power.
Nibbib
Post by Nibbib »
Okay I can not for the life find the relay... I know it's red but how far up in the dash is it I have the diagram
Post by SILINC3R »
If it has never been removed then you will probably have to pull the dash. The reason being the relay is clipped into a bracket. With the knee panel removed if you cram yourself upside down by the foot pedals and look up and right above the ECU you maybe be able to see it.
Nibbib
Post by Nibbib »
Damn.... I was hoping I wouldn't have too pull the dash...
