Kevin's swapped L sedan, 550 robtune td06 20g, 305whp @17psi
legsportwag
Re: Kevin's swapped L sedan, 550 robtune td06 20g, 305whp @1
Thanks and yes you can swap everything over. Although its a lot of detailed work. Building a transmission is serious business
Re: Kevin's swapped L sedan, 550 robtune, td06 20g
legsportwag wrote:ha your 2nd looks like my first dam these weak transmissions! Im wondering if anyone would know?? say i where to open up a 4.11 cable 5 speed legacy/impreza trans i have could i swap all the internals over to my 91 hydro case and benefit from the shorter gear ratio yet still retain my hydro clutch setup just a thought would it even fit ?
That's what's In my 92 right now. N/A Legacy 4.11 gears in a turbo case. I gotta tell ya, 70mph at 3k cruising is quite nice versus the 60mph at 3k I got with a legacy turbo transmission. I drive a lot so that mileage made me real happy.
It's tedious work to do, but it can be done for sure. You have to swap EVERYTHING. Shift forks and shift rods as well.
I'd be be happy with a 5th from a 4.11 or 3.90
Oh yeah, I forgot I came down there and helped you on yours.
robertpaige
Stoked on those numbers!
jessman1942
Thanks for the advice man ill be picking up a 4.11 trans very soon and parting out my 3.9 one im done it will be alot better on my ej20g
88 Honda civic wagon B20VTEC SWAP-RIP
85 Subaru loyal sedan-SOLD
95 Subaru impreza $500 BEATER-SOLD
91 Subaru legacy SS jdm ej20g swap
CHECK OUT MY ej20G BUILD HERE>> viewtopic.php?f=25&t=53766
legsportwag
jessman1942
what where the numbers !!!!!!!!!!!!!!!!:)
None of my friends including myself have had a failure yet using the 05+ LGT 4.11FD 5mt. All cars are 350+ whp/wtq. All of us had blown up the weaker 5mt on multiple occasions. Just a thought for a cheaper option...the gears are thicker I believe.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
legsportwag
Updated vid to include plot in same post
jessman1942
NICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 305 awhp
Are the speed sensors on the transmission or at the hubs? I guess it doesn't matter if you wanna buy a vsspro, but I thought I would ask.macipusy wrote:None of my friends including myself have had a failure yet using the 05+ LGT 4.11FD 5mt. All cars are 350+ whp/wtq. All of us had blown up the weaker 5mt on multiple occasions. Just a thought for a cheaper option...the gears are thicker I believe.
legsportwag
The speed sensor is on the transmission, but it is electronic vs speedo cable. It does require a speedo gear swap as well, for correct signal output.Are the speed sensors on the transmission or at the hubs?
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
legsportwag
Mmmmmm v3 sti wheel
Awesome launch. Love the cockpit layout.
legsportwag
I've put a lot of thought into cockpit layout as I drive the shit out of this car. Best daily driver I've ever had..
legsportwag
Also finished up the cruise control and horn button... Clock spring delete! Functioning horn as well as cruise is nice.. I used a 00 2.5rs cruise stalk with cancel function and it even works! Super happy.
robertpaige
Looks great.
ride_child
awesome ss dood! so the blue label svx maf is able to flow enough air to get to 22 psi safely with the 550 robtune? i know that traditionally the maf is the limiting factor with the robtune.
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
'91 Black SS - SOLD
legsportwag
Also injectors.. The stock green label is capable of maxing out the 525 sti yellows. I had it tricked by bumping up my fuel pressure to put my injectors into over drive. This will cause it to run rich under any conditions other then full boost.. I used an apexi AFCneo to correct the lower rpm by messing with maf voltage. I put my car back to stock for fuel economy. My next step will be a z32 maf with 1000cc injectors. I'm in the reasurch stage of hacking into the ej20g ecu again so I can play with the fuel and spark maps..
ride_child
sweet, thanks for the clarification!
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
ride_child
also can you post some pics of how you did the clock spring delete?
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Yeah, I'd like to see some additional pictures of the cruise setup.
I had always wondered if the cancelling cruise could be swapped over. Now I'll be doing that too
