I just finished up building a 22T/25D hybrid engine in my 1993 SS.
I fired it with no coolant (radiator was broke) and it runs ok (only ran for a few seconds)
Last night I got a new radiator and filled it up. Went to start it, and it started ok but immediately died. Tried a few more times and just a click. The engine hydrolocked.
Somehow, the water from the cooling system is getting in to the oiling system, and I cant come up with how.
The lowermost expansion tank hose is going to the water pump hard line
The next lowest one is going to the Turbo top line
the next lowest one is going to the radiator nipple
the highest one is going to the coolant overflow.
The only thing I can come up with is that the person who drilled/tapped the heads for the turbo maybe drilled too deep with the oil drain and hit a coolant passage?
any other ideas before I pull it back out and replace the heads?
25D hybrid, Big problem (coolant in oil)
Re: 25D hybrid, Big problem (coolant in oil)
Only other thing I can think of is improper alignment of the head gasket. But it's probably more likely that the person who drilled the holes for the coolant & oil lines screwed up.
Can you elaborate how the motor "hydrolocked"? Was the entire crankcase filled with water/coolant? When you drained the oil was it all foamy looking?
