MSD Coil
MSD Coil
Just looking to hear from others with this mod.
possible dyno results would be great
Fuel economy ect?
Fuel economy ect?
Not sure if this helps, but this is Dave's experience with it:
http://legacycentral.org/library/DIS.htm
I like mine. looks great, built to last, inexpensive......
mounts on in basically origanal spot with NO hood interference.
But only two out of four bolt holes line up.
I didn't like mounting it with only two bolt holes because of the vibration that would be present on the unattached side.
So i cut and drilled a plate of alum.
And switched the stock plug wire ends for L shaped to match up to the MSD.
IT idled better( snottier) and ran crisper, but the wires and coil i took off were hurtin.
"Hows the transition look?"
91 turbo manual
BMX in the trunk!!!
91 turbo manual
BMX in the trunk!!!
mexicanzero
i've had mine on for over a year now and i dont think there was much perforamnce gain maybe max 5hp? but the sound changed it made the exhaust tone lower and angryer but the main reason i did it was for fuel economy. after having done just the coil, plugs and wires and stuff had already been changed, i gained about 50km to a tank.
and it only cost like 80$ or so for the coil, shipping and connector off a neon.
do it!
do it!
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
word, thanks guys.
m zero, do you have a link from where you purchased your parts. or could you tell me the best way to go about finding one for cheap.
i take it you got yours from canada.
mexicanzero
http://www.msdignition.com/Products/Coi ... 96-on.aspx
thats the coil you need as well as the connector off a dodge neon of the years it says on that page.
i got mine online probably from the states, i'm not sure what site exactly it was long ago
http://www.sl-i.net/FORUM/viewtopic.php?f=39&t=11704
this is a good page about a guy who did it to his subaru
therea a better one on that site i think the search engine on the site has gotten confusing though
these are acouple of places you can start looking for a good priced one, maybe even ebay?
http://www.amazon.com/MSD-Ignition-8239 ... B00068OKZ2
http://www.shopping.com/xDN-automotive_ ... s-msd_8239
njdriver04
Re: MSD Coil
Just got my MSD coil in the mail. Think $80 shipped from Summit, came in two days. Anyone with old coils should replace them with these cost half as much as the stock coil from the dealer, will post pick of the entire install.
'04 forester XT
Scoob Alumni
'94 TW, '96 L, '00 GT
Scoob Alumni
Re: MSD Coil
You can save alot of money by just going to a pick and pull and getting a coil off a Neon. You need the Neon connector anyway so just pick up the coil at the same time. The difference isn't worth the money.
Jeff
Jeff
njdriver04
Re: MSD Coi
Can't agree with you on that, used coil is a used coil. Anyone with a high mileage coil pack should consider replacing it. I'm not a nasioc snob, I am sorting my TW out to get it running like a top.
I was looking into replacing my coil, from the dealer I think it was upwards of $150 from Liberty Subaru. I admit I didn't look at the price of the neon coil new but the price of the MSD coil was within my budget,
'04 forester XT
Scoob Alumni
Scoob Alumni
Re: MSD Coil
Just to note, if you go with the MSD coil, you will need to run the newer style spark wires meant to mate with the male coil vs. the stock coil which has female connections.
njdriver04
Re: MSD Coil
I was planning on crimping on a female connector, need to find something that will work
'04 forester XT
Scoob Alumni
Scoob Alumni
Mattheww044
Re: MSD Coil
what kind of wires would you buy then? The "DIY plug wire kit"?
Re: MSD Coil
You could probably get wires for newer model Impreza ej22's. My 97 Impreza has a 2.2 and has the male style connectors on the coil.
njdriver04
Re: MSD Coil
little side by side comparison for ya'll
'04 forester XT
Scoob Alumni
Scoob Alumni
Re: MSD Coil
What is the part number for the MSD DIS-2 unit? They seem to have a buttload of different ones. It looks like maybe the 62112 but that is $600.
Re: MSD Coil
The older one (one in my car) is 6211. It appears there's a new version and that part # is 62112. You could see if there are any of the older part # DIS-2's on ebay for cheaper.
Re: MSD Coil
Thanks!
