Fuel pump problem
tinyturbo10
Fuel pump problem
I've been working on swapping my engine and transmission into a new wagon shell after my sedan was totaled a couple week's ago. I got it all put back together and in the wagon, but when I try to start it, it cranks but won't start. I figured it was probably something to do with the fuel pump so I took off one of the fuel lines right after the fuel filter to see if gas was getting to that point and nothing. No fuel came out of that line at all when I tried to start it. I swapped the fuel pump from my old sedan into the wagon and still had the same problem. I looked at the plug underneath the back seat to see if it was corroded and it was fine too. Anybody have any other ideas of what it could be? I was thinking possible the relay under the dash but haven't had time to look any further into it.
Re: Fuel pump problem
Have you checked the ground on the back of the intake? That grounds the ecu and sometimes that gets overlooked especially in a swap.
Charles
tinyturbo10
Yeah that's all good. I'm gonna try to replace the relay tonight and see if that works. If not I was reading some other threads and saw that some people just bypassed the plug under the seat and it worked so I might try that too when I get a chance.
Might want to try the plug bypass before the relay, from what I've read on here that seems to be the more common culprit and is much easier to do than getting that relay out.
tinyturbo10
Yeah I'm thinking the same thing after reading a bunch more about it. I'm gonna check to see if the plug under the seat is getting power first then go from there.
tinyturbo10
It was the relay
