dankberries
Post by dankberries »
Legacy777 wrote:I was talking with a friend last night....it's always cool get stuff in the mail from other countries :)
Except the 45 day wait. Give or take customs time. Or for some maybe that builds the anticipation.
Either way its exciting, I like when its all written in Japanese and I have no clue what I'm looking at but its awesome cause its JDM!
My wife thought I was saving my headlight package from Poland for some sort of sentimental value. LoL I left it around for fire starter, I had to ask her why she never used it too start a fire (fire place).
Couldn't be mad at her, just happy to have a Lady that knows how to start a fire on her own.
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Got to drive the 92 for the first time since october 2013 yesterday.
Scruff_
Post by Scruff_ »
cj91legss wrote:Got to drive the 92 for the first time since october 2013 yesterday.
Yes! Thoughts?
1991 Subaru Legacy SS 4EAT (awaiting manual swap)
1994 Subaru Legacy TW
2001 Toyota Sequoia
speezly
Post by speezly »
Best feeling ever?
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
Yes! Thoughts?
Only drove it around the block. Only got into boost for a little bit. Let's just say it was borderline boner causing. This thing screams. When I get the full tune, I will try to dyno.
Best feeling ever?
That's the least to say. It's been a year and a half.
sqc151
Post by sqc151 »
sold my tw today.
im just happy its in good hands.
What are you driving now?
sqc151
Post by sqc151 »
im still in the process of stripping the 93ss. ill post those parts in my fs thread when they are removed.
but thats my long term resto project.
as for driving, i have my 14 tacoma and 11 fxt.
selling both and getting a CTS-V sedan and gonna look for another 1st gen legacy to daily drive.
bcmaxx
Post by bcmaxx »
Mounted up my new turbo bumper on the ls . Just need to find away to fasten the fog fillers. Not sure why but theres nothing to clip intp
allnines'
Post by allnines' »
^^ lime green calipers-eww! ^^ Thought, I would love to have a supercharged caddie wagon!
Legacys are like potato chips-you can't stop at one!
speezly
Post by speezly »
sqc151 wrote:im still in the process of stripping the 93ss. ill post those parts in my fs thread when they are removed.
I daily drive my 93 resto project, lol. I'm hoping in the end my legacy will look half as good as yours does right now. That interior looks so nice. Mine not so much...
Image Image Image
On the bright side of things, I got a chance to install some 04 Wrx brakes and rotors all around. I did however, completely forget to install the Svx non-abs master cylinder and prop valve I had hiding in a box Image Image
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
sqc151
Post by sqc151 »
thanks, most of that interior is coming out now. time to change it up a bit.
nice job on the brakes. good upgrade from the L.
speezly
Post by speezly »
Keep me in mind if you want to get rid of anything you upgrade. My goal is to have my L transformed into an SS by this time next year
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
allnines' wrote:^^ lime green calipers-eww! ^^ Thought, I would love to have a supercharged caddie wagon!
Actually, I like those on that car :)
speezly wrote:On the bright side of things, I got a chance to install some 04 Wrx brakes and rotors all around. I did however, completely forget to install the Svx non-abs master cylinder and prop valve I had hiding in a box
I'm pretty sure CJ (cj91legss) is looking for a non-abs SVX master cylinder if you don't plan on using it. Just as an FYI, you wouldn't want to use the SVX prop valve, you'd want to stick with the Legacy valve and swap between wagon and sedan if needed to shift the bias a little under heavy braking.
I am :-)
allnines'
Post by allnines' »
DAM-that's a lot of green!
Reinstalled the engine in my 95 Leggy L, I resealed the back.
thewaterboy
Post by thewaterboy »
Swapped my failing alternator for an 06 Outback 110a unit from the wreckers. Happy with it thus far.
bcmaxx
Post by bcmaxx »
Momo swap. So pleased! Thewaterboy . Was that a direct swap?
thewaterboy
It bolts right in, but the plug has to be swapped to the rectangle plug. I'm fairly sure I got it correct haha. There is a Sense wire, Ignition switched wire, and a dash light wire from both old and new plugs. It helped that the junkyard gave me the pigtail with the alternator. There is some conflicting information on it, with some sources saying you only use 2 wires, and some saying you use all 3. I've got all 3 hooked up so far, and no issues to speak of.
speezly
Post by speezly »
Good to know. I just assumed the larger master cylinder would need the matching prop valve. Trying to learn as much as I can. And I hunted on car-parts.com for a while and I came across the master cylinder.
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
If you have stock ss brakes, I used a 1" non abs master cyl and pro valve. Seems to work fine so far. I don't do heavy braking.
I do plan to upgrade tho since I also want some 4-2 pots.
I didn't know the sedan and wagon were different as far as the prop valve tho. Is there any physical way to identify them?
