Overtaking a Porsche!
Member's Car Thread
Re: Member's Car Thread
That's quite a bit of snow!
meatball671
this is my 1992 wagon N/A 5MT, I bought it for $750 from a dealer, it was a one owner car, it has 142,000 miles currently. I put a full exhaust on it and 2.5rs rims and a snorkus intake. The only thing that was wrong with it was the rear subframe was rusted.
Jonah
92 legacy wagon N/A 5MT
93 legacy sedan 25th anniversary edition 02 wrx swap ver 2 jdm 5MT
93 legacy TW 25th anniversary edition 4EAT stock with supporting mods
94 legacy TW 4EAT built ej22t vf-34 CES exhuast
allnines'
That's why I had to part with my '91 wagon-no time to tackle itmeatball671 wrote:this is my 1992 wagon N/A 5MT, I bought it for $750 from a dealer, it was a one owner car, it has 142,000 miles currently. I put a full exhaust on it and 2.5rs rims and a snorkus intake. The only thing that was wrong with it was the rear subframe was rusted.
Legacys are like potato chips-you can't stop at one!
93wagonship
Hi all! I'm from Brazil and I'm glad i've found this forum which is very specific for my Legacy (BF 93 2.2 GX). Here's a pic
cheers
cheers
Wagonship: 1993 Legacy BF (High Roof Touring Wagon) EJ22 5-spd manual with low range \o/
93wagonship
bought it from first onwer so it's Ok for the age. But always have something to do, which is the fun i wanted in the first place
e aí beleza, tá bem apresentável a máquina, tem detalhes de funilaria e um outro vazamento, mas de motor tá bom. Tô rodando direto na estrada, uma delícia de carro. O resto vou fazendo aos poucos. A revisão inicial pra tirar do repouso ficou salgadinha, agora é aproveitar
Vc de qual cidade? Qual modelo possui?
Rammster wrote:bonita hein, parece bem novinha93wagonship wrote:Hi all! I'm from Brazil and I'm glad i've found this forum which is very specific for my Legacy (BF 93 2.2 GX). Here's a pic
cheers
Welcome to the BBS! Now I think we have at least two members from Brazil.
Man that BF is tidy!
colemanapp
after a 92 TW legacy, a 98 BG9 and a 04 SG5 Forester my 4th Subaru
the most rarest model in Brazil a 93 GX with sun roof
92 Legacy Wagon Awd
That's a really clean wagon! Whatever you do, don't break that auto antenna. Working ones are basically unobtanium, and unique to the 2nd gen wagon. The 1st and 2nd gen sedans share the same auto antenna, or at least they interchange.
stuffedx24
1993 Subaru Legacy Turbo - New to forum
Hey guys, so new to the forum but I've been involved with Subaru's for 3 years now. I've had 3 Fist Gens and 2 JDM WRX WRX Impreza GF8s.
Will be making a build Journal once I have more parts on it. Has lots of new OEM parts Mainly at the moment.
This my 1993 Subaru Legacy Turbo.
I bought it running but in need of Motor work for $1000 CAD.
Its Automatic with 146,000km original km.
There's only small surface rust on the right rear quarter panel and drivers side door trim that I'm fixing this year along with new paint.
So far I've dumped my money over the winter into rebuilding the EJ22T. Rebuilt it factory spec with new seals,timing belt, heads rebuilt, cams polished. I wasn't able to find any good condition EJ25 heads so that's why its still SOHC. Want to enjoy it first before I go into a DOHC build.
I have Racelands Coils for it. Not installed until spring.
Front and rear new calipers, rotors and pads
Stripped the interior carpet out, tucked and re wire loomed.
New Walbro 255 Fuel Pump
EJ20G TMIC, still have to install
1529757_10155550919210357_6504078077717329324_o by Billy Majeau, on Flickr
IMG_5707 by Billy Majeau, on Flickr
Rebuilt EJ22T heads with new Valve Steals and cleaned up.
11891460_10155969233680357_1268387233331918066_o by Billy Majeau, on Flickr
P_20150901_190615 by Billy Majeau, on Flickr
New Gates Timing Belt kit
P_20151106_194601 by Billy Majeau, on Flickr
How it sits now.
IMG_8018 by Billy Majeau, on Flickr
11875228_10155885379710357_8625186117569021532_o by Billy Majeau, on Flickr
This was my last Legacy, 92 Lifted on Forester Struts. Sold it though. Miss mudding in it.
20150307_203234 by Billy Majeau, on Flickr
Cheers
IMG_5707 by Billy Majeau, on FlickrRebuilt EJ22T heads with new Valve Steals and cleaned up.
P_20150901_190615 by Billy Majeau, on FlickrNew Gates Timing Belt kit
P_20151106_194601 by Billy Majeau, on FlickrHow it sits now.
11875228_10155885379710357_8625186117569021532_o by Billy Majeau, on FlickrThis was my last Legacy, 92 Lifted on Forester Struts. Sold it though. Miss mudding in it.
20150307_203234 by Billy Majeau, on FlickrCheers
Just getting started on my 92 legacy wagon RWD build.
No "mods" yet, but did 4eat to 5mt swap and cut the springs like an idiot haha
Also have some toyota matrix 16" wheels on her for now.
Her name's "Smokey" (given to her by previous owner but seems fitting for a tire slayer)
[img]content://media/external/file/54390[/img]
RWD is fun. Just remember that the axles won't last wether you weld or go LSD in the rear. If you plan on keeping it go with a higher gear ratio R160 with dss axles or an R180 swap. For my rwd 94 I'm having someone in your vicinity chop up some knuckles and move the tie rod mounting point an inch in. More steering angle is a must for staying in a controlled slide ;0wagleg93 wrote:Just getting started on my 92 legacy wagon RWD build.
subiedoutlegacy
New Jersey, USA. My 1991 Legacy Sport, Robtune 550 tune & supporting mods with 95 RA Trans.
20160514_193213 by Stephanie Apgar, on Flickr
FB_IMG_1463350895081 by Stephanie Apgar, on Flickr
FB_IMG_1463350895081 by Stephanie Apgar, on Flickr91 Mica Ruby Legacy Sport 550 Robtune
94 White Pearl Legacy L SOLD
04 San Remo Red Impreza WRX
04 Java Black Pearl Impreza STI
94 Crimson Pearl Legacy Sport Partout
Got my outer tie rod mount holes moved in an inch. Low heat, high nickel rod and good bevels was the recipe. Going to throw them on soon.
93wagonship
First time out with a 360° camera (don't know how to embeb this in the message, so her's the links)
https://theta360.com/s/efAz0C5lVVpPIIvHQBx0XobB2
https://theta360.com/s/r5MKHY5pu6AalyRrqnUWauQhk
https://theta360.com/s/kMJRrXM2pwX7n7iGLXxtPJhZ2
https://theta360.com/s/sSqJmcTicF8XAY3aDrNN151Rg
Those pics are really cool 93wagonship! I don't think it's possible to embed those on this older forum software.
I did notice Flickr lets you upload those pics intact. When you share the link under "bbcode" on flickr, it shows just a static image till the viewer clicks on it. No better than using Ricoh's website.
93wagonship
thanks for the tip bud
sorry for the lack of focus on one side, I'm pretty sure I'm already solved it yesterday..
ProxyGrave
Hello Im From Russia
My Legacy 1992 USA
EJ22 430.000km
My Legacy 1992 USA
EJ22 430.000km
Welcome everyone!
We're getting a worldly following
What camera was used on those 360 degree pictures?
