Miguelones Australian Delivered RS Turbos
Re: Miguelones Australian Delivered RS Turbos
Are you still on the legacy ej20g heads?
Yup still running rocker arm heads.
If you could find some ej20k heads on the cheap, they are a worthy upgrade. Either kind revs all day!
I like the early heads. Might not make as much power but nothing can compare to that growl.
You might also have the group-a style headers that I've been casually searching for. They produce great sound. I don't doubt that your heads also contribute however.
here is a comparison: (replace USDM with "non group-a style stock headers")
Legacy777 wrote:94Leg-c wrote:Josh, which of the two is the jdm?
JDM is on the left
http://www.main.experiencetherave.com/s ... G_0982.JPG
JDM is on the right
http://www.main.experiencetherave.com/s ... G_0989.JPG
You can see how the JDM manifold is larger and has more runner length.
what is the suspension on this car?
