'02 WRX Steering Wheel Swap
valpaval15
So I bought the car with the momo yellow arrow wheel already installed ('93 TW) and it has the airbag light on. I'm assuming there's a way for me to read codes from that light but I have no idea how. Also there's an sea module under my center console. Could that be for the wheel itself? Any help is appreciated, thanks!
Re: '02 WRX Steering Wheel Swap
The momo airbag is from a far newer car than yours, and the plugs are different. While you probably can splice the wiring to your cars', I would be nervous about accidentally setting off the airbag. Personally I would just take out the airbag light unless I found a 93-94 airbag steering wheel which would work.
valpaval15
That momo is way cooler though haha, I was just thinking it would be an easy fix.
