Pntaste4evr99
Winestone Cowboy
Post by Pntaste4evr99 »
All I used mine for is defrost, but taking it out does take some weight off, u know, RACECAR!!!
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
dankberries
Post by dankberries »
Dropped my newly acquired 25d heads of to a machinist recommend to me by a good friend. My friend worked at a machine shop for 30yrs and one of the the guys he worked with started his own independent business. Because it's a friend of a friend the guy was willing to work on my heads earlier than later.
This time of year most all of the shops are super backed up. Everyone else I contacted was backed up to march. Winter time build, summer time race.
After meeting the new machinist I have never felt so good about having someone else work on my stuff. This guy was incredibly knowledgeable. He has all the right tools to get major jobs done, CNC , flow bench ect.
In the work order I requested a cleaning, resurface, valve guides, valve stem seals, 4 angle valve job, and a little polish on the cam journals.
Also got valves orderd. I decided to pick supertech valves basically for availability. Ferrea custum valves would take a couple months to get and more $$$.
Standard size intake nitride coated and standard size inconel nickel exhaust valves. Never used supertech before but hear good things.
I really only wanted better gas mileage for the legacy but its quickly taking a bigger path. :roll:
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
dankberries
Ordered more parts today. Subaru Warehouse Online has everything discounted to clear inventory with an additional 20% off coupon.
Just saved $100 on a $400 parts order.
New gaskets, seals, o-rings, studs, nuts, pumps ect.
Getting closer and closer to Project Legacy hybrid by the day. Shiney new parts :smt041
90 Nissan 240sx 2jz
speezly
Post by speezly »
dankberries wrote:Ordered more parts today. Subaru Warehouse Online has everything discounted to clear inventory with an additional 20% off coupon.
What website is that? I always need some shiny new parts.
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
Replaced HGs in my Outback. Had a shattered knock sensor and replaced that too. Did the job outside in 20 odd degree weather, leaving the engine in car. Brrrr!
dankberries
Subaru Parts Warehouse
20% off coupon expires tomorrow, enter YE15 at the end of checkout.
mike-tracy wrote:Replaced HGs Did the job outside in 20 odd degree weather, leaving the engine in car. Brrrr!
Working in the cold sucks! Things dont move as easily! Ive never done HG's in the car, I always figured it would be easier to pull the engine. I thought there wouldn't be enough clearance, especially with DOHC.
90 Nissan 240sx 2jz
speezly
Post by speezly »
Started stripping my newly acquired ej22t. Just dropped the heads off at the machine shop, getting ready to ship the cams to delta for the 220 regrind.
93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
Pntaste4evr99
Winestone Cowboy
Not much but put in my whiteline front sway bar last night, man what a difference over stock bar. Now just have to save for the rear.
Couple weeks ago the ej22e in my outback blew its head gaskets. I replaced the gaskets, but the water pump leaked ever since. I resealed it several times, but it would always leak between the pump and the block.
The surfaces were both polished and flat, and the last 2 times i used RTV on both sides of the gasket. Same result.
My conclusion is even though my block and heads were still within spec for flatness, i actually warped the waterpump! I put a new oem water pump and gasket and also waterpump rated rtv and so far so good.
There's a hole on the pump they start leaking from when the bearing goes bad. I believe it's called a weap hole.
Stephan is my witness, it was leaking from where it mates to the block, lol.
dankberries
I hate 23 year old wiring. Just wanted to vent that out.
This week I've had an intermittent check engine light. I get about 8 codes but I've narrowed it to a short in the knock sensor wire. It's extremely brittle and any time I try to move it more cracks form. I've noticed by jostling it I can get the CEL to disappear. It was good for a couple days but its back. Limp mode is my favorite... *sigh*...
If I have time this weekend I will likely need to run a new wire from the sensor to the ECU .
I think when I do my DOHC hybrid I will take the opportunity to run new wires for a few sensors and possibly build a new engine harness.
90 Nissan 240sx 2jz
Pntaste4evr99
Winestone Cowboy
I put a new shifter boot and knob in tonight, don't know if I like it but trying it out
dankberries
Woohoo no more CEL !
I couldn't wait for the weekend to fix my knock sensor wire, the power loss was unbearable, so I left work early today to tackle the problem.
Lucky for me my work has a spool of a couple hundred feet of this high grade shielded wire, it was from an old project so I can take as much as I want/need.
Ran new wire from sensor to ECU.
Test run after install @13lbs
90 Nissan 240sx 2jz
Pntaste4evr99
Winestone Cowboy
I use that same type of wire to install cop push bar lights and roof lights on the rigs at work
Do you guys know the wire type or where to purchase it online as I'm sure a lot of other people could use that info because the stock knock sensor wire is shot.
dankberries
Legacy777 wrote:Do you guys know the wire type or where to purchase it online as I'm sure a lot of other people could use that info because the stock knock sensor wire is shot.
When I go to work on Monday I will check out the manufacture and or where we got it from. It came in a 1000ft spool. I have two kinds of that same type at work, one is 22 gauge and the other is 16 gauge, both have four wires with a foil shield and shield wire around the foil, also a fiber as well.
90 Nissan 240sx 2jz
I found a spool of shielded wire at my old job that another guy I worked with was going to just scrap. Fortunately I saved it's life and put it to good use. Hell I even used it multiple times on various sensors on my old harness. I even have some left!
marsh27
Post by marsh27 »
Rust proofing the tleg since Illinois likes to use an awful lot of salt on our roads
93 fwd beater wagon
93 tw build in progress
mr.blub.blubs142
Post by mr.blub.blubs142 »
Found a mud pit in the woods...it was nice...very nice
dankberries
Had an absolute blast this last weekend taking full advantage of the epic snow in CO. Built a tree jib and a couple jumps for snowboarding, used my awesome lights on the legacy to light up the way:
tree jib
snow jump
Attached a ski rope to the back of legacy and pulled my friends from behind all the way up Mt. Evans to Echo ski resort where we snuck in at 2am and did a couple runs. So much fun!
90 Nissan 240sx 2jz
mr.blub.blubs142 wrote:Found a mud pit in the woods...it was nice...very nice
Pics or video?
bcmaxx
Post by bcmaxx »
smoked my side markers, replaced my ebc solenoid ( was stuck at 9psi) , now to just get rid of this snow so I can install some more goodies!!!
pleased with the end result
10wrxing
Post by 10wrxing »
I'm still waiting on them, but bought a heated seat kit for the Legacy.
I'm hoping that pulling the seat upholstery up, and putting it back down will be as easy as I think it is....but nothing ever is.
I'm also kicking around buying a heated mirror kit off ebay, but not sure I want to risk playing with the mirrors.
rallyak
Post by rallyak »
I would just find some heated mirrors that fit our cars and just bolt them on.
Charles
