Hey guys. I have a 85 Brat with a new 2.2T, never been fired yet, and I am getting ready to test fire to make sure I have the harness good to go.
Some questions:
I wired in the Ej alt to the Ea harness and I have it:
Ea Big white wire goes to Ej Big white to Lug on Alt; it also splices and jumps "white" to one of the wires on the round alt plug.
Ea white to Ej yellow on round alt plug
Ea -white/red stripe to Ej- Black/white stripe
Is that right????
Also, on 16 Pin, B56 connector, terminal 10 says red/yellow and blue/red, goes to Ign sw, P, N.
Off my 16 pin conn., it jumps up a wire size, still red/yellow, with the end having a female spade connector.
Does that go to the starter?
Plus, what do I do with the blue/red wire????
Ej to Ea harness
Naked Buell
Ej to Ea harness
86 Brat, 2.2T, AWD, TD04, Intercooled,
88 Rx, Future EJ upgrade soon
Naked Buell
Re: Ej to Ea harness
Hey I found the info on the B56 pinout, on the sticky, first post on this section.
Anyone confirm the hook up on the alt???
Are you still looking for this info?
Do you have a wiring diagram for the EA motor?
