I agree-these cars are, by far, "best in snow"NICO wrote:allnines' wrote:Boy-do I miss my '93 loyal-just got the D.S. front floor mat and one of the rear windows.
i love this wagon cant wait to swap it so i can keep up in traffic lol
well the new year has lots of snow days in it which the Loyale slices through like a hot knife !.. two feet of snow BLIZZARD cant stop this little wagon.
92 Subaru Leone Touring Wagon
allnines'
Re: 92 Subaru Leone Touring Wagon
Legacys are like potato chips-you can't stop at one!
allnines' wrote:I agree-these cars are, by far, "best in snow"NICO wrote:allnines' wrote:Boy-do I miss my '93 loyal-just got the D.S. front floor mat and one of the rear windows.
lol this year is sure fun, snowing agian right now like crazy...
1989 enkie meet 1992 enkie, perfect fit caps in retro style..
well I guess stoptec rotors came in... guess ill use them after all..
What a mess this week was !.. after losing a brake line to rust it was time to strip this wagon down and start phase 1 of the project.
who ever owned this car before me just didn't like to grease anything !
cv axles where rust/weld to the rear diff and hubs ! disaster
front axles where some knock off junk crap that had to be cut off !.. axle looked new and at 100kms the front would shake like I had all my rims and tires unbalanced !
Oem Subaru front brakes, rotors, bearings, seals, bolts. cv axles all re done with oem boots clamps and grease, also kyb shocks installed, whiteline 20mm sway bar.
Oem Subaru rear disc turbo brakes conversion rebuilt with all new parts, bearings, bolts and XT6 rear arms with the 20mm sway bar and new kyb shocks.
rear has all the bushings for that tight feeling like my white sedan with the xt6 moustache bar for the bigger bushings, braided brake lines all around.
how does is drive so far... just amazing what new brakes bushings and shocks can do to a car feel.. 100km+ feels smooth as butter !... the motor is now the weak link and needs more power to over come the good handling with stopping power.
Looking good Nico!
Legacy777 wrote:Looking good Nico!
thanks Josh.. its just my DD with a little extra stuff.... need to swap it soon with a NA 2.5 motor for that extra cheap fun lol.
so since I wont be needing any of my hsd coil overs on my sedan I decided to use them all on the wagon.
so after thinking about it I came up with this ice cream cone cup idea... the front hub on the old subarus had a slide in shock like a ball joint and bolt holding it in...
got a machine shop to wip up a cup that slides in my stock hub and he made threads so
I can add coil overs in the top.. there is also a hole in the bottom so I can adjust the coil overs with a allen key...
the rear ill use spherical bearings and a new top hat I got coming.
allnines'
It's time to take a road trip to Canada to see all these great, classic scoobies!
That's a very cool solution to retrofit new parts to the old subie.
lol thank you... let me know if you doallnines' wrote:It's time to take a road trip to Canada to see all these great, classic scoobies!
lol I surprised my self looks like it will work out well, once my other car comes out I can swap the ohlins for the hsd and use the hsd on the wagon... another couples weeks ill pull it out and see if the plan works..Legacy777 wrote:That's a very cool solution to retrofit new parts to the old subie.
I didn't want to change hubs and brakes on the wagon that's why I decide to make that cup thing..
so instead of breaking the bank in making a rear top mount, I had some tein top hats kicking around and decided to use the centre section that un-bolts and holds the spherical bearing in place.
the bearing need to be replaced and the aluminium ring busted so I got my machine shop to make me new new rings with 6 point 30mm socket on it.
ill get the same hole size drilled in my stock hat and weld it in place and get it powder coated so it last long time.
summer tires check mark...
Nankang NS-2R 185/60R14 treadwear index: 120 (for racing) 86(XL)
http://www.nankang-tyre.com/home.php?fn ... v2=7&no=12
they should keep the 70hp wagon glued around the corners this year, 350 bucks how can you go wrong lol
Those look pretty wide for 185's
Legacy777 wrote:Those look pretty wide for 185's
r comps are more wider i was told, works for me lol
finally found a JDM bumper for my car in japan, this is the RX Leone one its got super light weight jdm beam and means i can finally mount all my OEM subaru fog lights to the wagon..
sand blasted and powder coated the JDM Leone RX bumper so it will last along time
light weight Leone RX JDM bumper is and all the Subaru Leone fog lights OEM
HSD coilovers with pillow ball rear top hats installed and just need to level it out a bit in the rear and it rides amazing. there is no camber adjustment on these old Subaru's but now i got camber plates and -4 deg lol
once it get warm ??? i can put my gold enkie's on for summer
Looks awesome with that bumper, and fogs! Wish I had a set of those enkies for my 84 GL. Well, I have a set of enkies, I just need to get around to the five lug swap so I can put them on...
1991 SS
1993 SS part's car, dead due to rust
1992 Legacy L wagon
1984 subaru GL wagon
1986 Brat (work in progress)
Several Air cooled VW's
1992 Legacy L wagon
i was going to swap the lug but decide to keep it simple, send me your build journal love to see it1982gl4 wrote:Looks awesome with that bumper, and fogs! Wish I had a set of those enkies for my 84 GL. Well, I have a set of enkies, I just need to get around to the five lug swap so I can put them on...
Insta-gram has more my updates on my subarus https://instagram.com/pinocchio_ok/
Well since I have a ton of subaru parts collecting dust and rust lol... ill use what I have accumulated over the years to make something simple and fun as my daily driver..
EJ22T block rebuilt all stock
EJ20k DOHC heads with EZ30 shimless buckets
S204 Oil cooler
V8-V9 twin scroll turbo
Vipec/link plug in ecu
91 Turbo Legacy 5mt wiring hole thing front to back Stock
91 Turbo Legacy 5mt 3.900
V8 STi rear R180 3.900 diff
XT6 Oem radiator Spal fans
should be fairly light and with a good power band pretty quick daily driver..
first think on order is clean the EJ20k heads then off to the machine shop for a CNC clover less chamber.
S204 Oil cooler
I wish I had this list of stuff "Just Laying around"NICO wrote:Well since I have a ton of subaru parts collecting dust and rust lol... ill use what I have accumulated over the years to make something simple and fun as my daily driver..
S204 Oil cooler
You sure know how to make a person jealous..
stipro wrote:I wish I had this list of stuff "Just Laying around"NICO wrote:Well since I have a ton of subaru parts collecting dust and rust lol... ill use what I have accumulated over the years to make something simple and fun as my daily driver..
S204 Oil cooler
I didnt build it i went easy this time so i can swap out motors when i cook them right away lol
so i decided to cheat and I got a JDM WRX NB editon swap with a 5mt 4.444 r160 with AVCS heads
i swapped out the intake manifold with a spare V8 STi and intercooler that i had kicking around
she fits like a glove and will have A/C
all most done now ready to bring it to my buddy Nam at NVauto for a nice clean stock ecu wiring job so it runs for a very long time
all most looks oem lol
meatball671
That's gonna be one fast Leone!!
Jonah
92 legacy wagon N/A 5MT
93 legacy sedan 25th anniversary edition 02 wrx swap ver 2 jdm 5MT
93 legacy TW 25th anniversary edition 4EAT stock with supporting mods
94 legacy TW 4EAT built ej22t vf-34 CES exhuast
meatball671 wrote:That's gonna be one fast Leone!!
light to light 4.444 gearing 13" rims
NEW instagram.... big_bad_wolf_xo https://www.instagram.com/big_bad_wolf_xo/
A/C in, XT6 radiator in, Clamps on, Fluid in... wiring time !
vacuum line adaptor all stock for the heater controls stock part, for the old school swapping guys lol
NVAUTO wiring harness built from the JDM wiring for my car.. AVSC JDM NBR WRX open source OBD2 ECU... stock on stock on stock !!
like my white Leone Coast Fab SS Race muffler to give it that pureeeeeee.. stock cats after turbo but up pipe delete of course lol
NVauto JDM WRX NB-R V7 V8 V9 STi wiring harness all complete ready to be added in the mighty LEONE SUPER Wagon !
so here is my new ECU in place and super clean job from my buddy Nam at NVauto
and of course I have OBD 2 now lol.. simple easy spot to put it in all most looks factory
dont want to but if i want to cool the intercooler something has to give.. maybe maybe front mount the top mount so it looks stealth out on the street..
so after getting all the wires and the car running last is the exhust set up.. here we have the oval 3" tube so it dosent scrap and then to the CoastFab muffler all is 304 SS tig welded at NVauto
so old school Subaru had the oil pressure on the dash, so I really wanted to get it to work so I have a gauge in the car.. after try many different ways I said F it off to the machine shop to cut this pipe thread down to the proper oil plug size..
top is original part bottom is after, fits like a glove and works perfect in the dash now
so after getting the car all done I had a problem with my R160 WRX 4.444 axles popping out the diff because there to short.. had to raise the rear and not drive around corners so fast to keep the axles in place..
so after building my other Leone with the V9 STi 6mt and R180 3.900 diff and having no problems at all.. I decide the only way to make this work easy is to find the most rarest diff Subaru made R180 4.444 = GC8 22B or TypeRA-R GC8.
some how some way the local JDM shops in Canada had one on had that no body wanted
22B R180 4.444 mechanical Monster !
also got my anttic rims 4x140 machine hub rings so no more shakes at 100kms and beyond
Nice video and good location of the camera! I like it!
