Rob tune
94LegacyT
Rob tune
Post by 94LegacyT »
Okay... I just got into Subaru turbos... Can anyone explain what this "rob tune" is?
Sent from my E6782 using Tapatalk
ride_child
Re: Rob tune
Post by ride_child »
type rob tune into the search bar and behold more information then you will ever need on the subject. or go to robtune.com
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
94LegacyT
Re: Rob tune
Post by 94LegacyT »
I was trying but what are the 440 and the 550? And is it just an ecu tune?
Re: Rob tune
440 and 550 refer to the injector size the tune is for. Check out his site, specifically the FAQ for more info. He says he is all out of chips.
94LegacyT
Re: Rob tune
Post by 94LegacyT »
Okay while i have ya hear. Do you by chance have any injector brands you recommend for my 94 22t? Or kinda point me in the right direction it just has a cold air intake on it that's it
nortonjefferson
Re: Rob tune
Post by nortonjefferson »
Site was updated today ROB HAS CHIPS AVAILABLE AGAIN! Just thought id put that out there lol
White 1993 L Wagon AWD 5MT-FXT lift, 27” MTs 380xxx miles
White 1991 L sedan AWD 5MT-(Robtune 550 DOHC Ej22t swap coming together) 187xxx miles
Black 2005 LGT 5MT-Ej20x swapped daily, VF40/elh
94LegacyT
Re: Rob tune
Post by 94LegacyT »
nortonjefferson wrote:Site was updated today ROB HAS CHIPS AVAILABLE AGAIN! Just thought id put that out there lol
Sure and I have to save to buy a new motor... Okay so for His tunes can I keep my stock turbo?
nortonjefferson
Re: Rob tune
I mean you could keep your stock turbo i suppose (i dont know this for a fact, can someone verify?) but that would kind of defeat the purpose of the Robtune eprom. The robtune allows (not only allows but requires) you to install larger injectors, one reason of the larger injectors is that most people upgrade their turbo to a TD05 (which is what the tune is based around) or something similar in size. Even a stock TD04 will suffice. I guess what im saying is you wont get the full benefit of the robtune with your stock turbo.
94LegacyT
Re: Rob tune
Post by 94LegacyT »
Okay never really messed with turbos. So not sure. But will that bolt up exactly the same as my vf11 or will I need new stuff?
nortonjefferson
Re: Rob tune
A TD04 or TD05 will bolt directly up to the stock 22t up-pipe
http://bbs.legacycentral.org/viewtopic.php?f=2&t=14145
94LegacyT
Re: Rob tune
Post by 94LegacyT »
Do I need new tubes then? Or have to get injectors right away or will it be okay to run with stock injectors for a little till I get extra cash.... Sorry for all the questions
nortonjefferson
Re: Rob tune
Hmmm, tubes as in vacuum lines and oil and coolant lines? Yes. Intake will need some slight modification as well i believe. As for the injectors they are a MUST for either robtune set-up to run correctly.
Read these threads top to bottom and comment if you still have any questions.
http://bbs.legacycentral.org/viewtopic.php?f=19&t=43744
http://bbs.legacycentral.org/viewtopic.php?f=19&t=47252
http://bbs.legacycentral.org/viewtopic.php?t=43959
94LegacyT
Re: Rob tune
Post by 94LegacyT »
Okay and I'm not used to this app yet. I'm trying to find how to see what injector style EJ22T have. Either side feed or top feed. I tried searching the site and can't find any.
Re: Rob tune
These cars have side feed 370 cc/min injectors.
I recommend trying to access the site from a computer or tablet and reading through some of the links posted that will help address some of your questions.
94LegacyT
Re: Rob tune
Post by 94LegacyT »
Thank you!
