Drove Great for another few Hundred Kms after the slipped TB was fixed, then no Speedo reading and code 33, VSS.
Removed the inner Speedo Cable and it appeared to be ok. Cleaned and re-greased it. re-installed, checked both end connections. Ok, drove it, still didn't work. Jacked it up on all 4's, disconnected the cable off the cluster. drove with the cable in my hand. Nothing, cable doesn't spin
Seriously, can't even make it 5000 Miles without something terrible going wrong. Driven this car 19 000 Kms and have pulled the motor and tranny numerous times. Had the Tranny re-built 15 000 Kms ago
What are my Options ? Do I have to pull and slit the tranny to replace that plastic gear ?
Seems like a retarded system
