EJ20G COOLANT CROSSOVER PIPE O RING GASKETS?? HELP!!!
scoobydoo94turbo
Looking for the part number for my ej20g coolant crossover pipe, engine is out of a jdm 95 sti impreza, doing the 20g swap into my 93 legacy turbo and want to swap 22t coolant crossover pipe to my ej20g engine to avoid cutting and extending the wiring, the 20g has o rings that are a smaller width vs the ej22t, cant find any info on google or on any forums consider im looking for a non usdm o ring part number. Any help would be much appreciated!!
05 Forester XT 2.5L Turbo DD 250,000km R.I.P
94 Legacy Turbo Touring Wagon 412,000km ) R.I.P
91 Legacy Sport Sedan 136,017km (parts car) R.I.P
04 Impreza TS Wagon 230,000km timing idler failed, being rebuilt!
94 Legacy Turbo Sedan 285,000km Mint DD
Re: EJ20G COOLANT CROSSOVER PIPE O RING GASKETS?? HELP!!!
I'm 99% sure they are the same part on every EJ Subaru engine. And I've never, ever had a problem with auto parts store ones.
Not exactly. The cars with the inlet under the manifold have a lower profile version. And some have an extra coolant temp sensor.
But they all should attach to the block the same way and have the outlet at the same spot.
peter@functionauto.com
