How to build it up?
Skid pad numbers are fine, but I find they bear little relevance to real world handling capability. The turbo Legacy will destroy any of those car in foul weather, too.
BAC5.2
True.evolutionmovement wrote:Skid pad numbers are fine, but I find they bear little relevance to real world handling capability. The turbo Legacy will destroy any of those car in foul weather, too.
The only real info a skid pad gives would be who can drive around a circle the fastest.
The beauty of All Wheel Drive
scottzg
swaybars do sooo much. a stock 2.5rs does a .82g's on a skidpad. a wrx has softer suspension and narrower rims (but the same width tires). it pulls a .87g.
Assuming the rs doesn't have a lead roof, the only difference is the swaybars. the rear bar on a rs is 13mm, the wrx its 20mm.
The rs has much more oversteer, making it easier for "joe idiot" to save his ass after he entered that turn too hot. A la honda.
rsstiboy
sounds like a really nice setup! how do you find the VF23 on a 2.2? i would have thought it would be a tad too small for that? upgrade to a TD05 it flows about the same as a VF22(5cfm difference between the 2) it will give you some more top end and responds to high boost and highflowing better than IHI turbos, how much HP is that at the wheels?kelley wrote:here's what my current set up is.
ej22t
ihi vf23
stromung turbo back
hks headers, blitz fmic,
and an autronic ecu. at 15 psi it makes around 400 crank hp.
I would recomend at least 550 cc injectors.
i hit full boost by 2500 rpm. hope thathelps you some.
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
eastbaysubaru
yes the vf 23 is ball bearing.
it works very nicely with the ej22t.
the way I have things set up i my redline is 6500 rpm with full boost at around 2500 rpm. I would have no problem running 20 psi with this set up as long as I had the injectors.
but I am building this other motor so I have not done much with this for a while.
boostjunkie
I think you might be right, Ciper.
Alot of the wrx (2.0L engine) guys haven't had success with the vf-series (even the vf-22) at high (~20psi) boost levels. Any that did, made short work of the turbo . . . within months.
BAC5.2
I disagree that 20 psi on an ej22t is out of the vf23's efficiency range. I have ran mine to 19-20 psi with very good results
this was due to a boost spike problem I was haveing with my greedy profec ebc. other than my dutycycle being at 100% by 12-13 psi no problems including no knock or detination. I wouldn't recomend doing this without proper fuel.
rsstiboy
i have to disagree, maybe their setup was poor, but there are plenty of guys running around 20psi on this turbo without problems, but in saying that the VF22 isn't as reliable at high boost as the mighty TD05!!boostjunkie wrote:Alot of the wrx (2.0L engine) guys haven't had success with the vf-series (even the vf-22) at high (~20psi) boost levels. Any that did, made short work of the turbo . . . within months.
