i just ran a 13.2 @ 105.88MPH!!!
rsstiboy
in my old RS liberty 2ltr, i can email timeslip for proof.
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
Great job, but shouldnt this be in motorsports
what was in the other lane?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
legacy92ej22t
rsstiboy
i was running 18psi, my LINK ECU still isn't tuned, i was running a base map, I have a TD05 turbo, 500HP fuel pump, fully modified fuel rails, bigger injectors, rising rate fuel pressure reg, 3" turbo back exhaust with extractors, cold air intake with pod inside the front guard, FMIC, twin plate clutch, ran that time with 17" rims and was having EXTREME PROBLEMS WITH TRACTION!!
Any reason you're using a rrfpr with the link? I thought you didnt need one of those once you had actual management? Cool stuff though.
eastbaysubaru
eastbaysubaru
eastbaysubaru
Allwheeldrive
Allwheeldrive
