where to get KYB GR-2's
well its time to replace my old GR-2's with some new ones. can someone recommend a place i can pick up a set of four? looking for good prices and a trustworthy online place.
Thanks everyone!
sam
Thanks everyone!
sam
tirerack is stupid when it comes to 90-91 rear struts. Order the struts from a 92-94 and it will give you the correct price.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
I don't get it... are you saying that the price Tirerack charges for the rear struts for 90-91 model Legacy's are incorrect? I was under the impression that they cost more because of the whole tappered spring and topmount.
Bob
90 Legacy LS AWD n/a -190,000 and going strong!
91 Legacy SS -currently stock and awaiting marginal upgrades (dead) RIP
That is why they cost more, but there's no reason for them to cost more. The strut is the same. Buying 90/91 rear struts from tirerack is a waste of money.
eastbaysubaru
You really do need a spring compressor. You should use one meant for McPherson struts; I have tried a pair that weren't designed with struts in mind and they just couldn't grab right, especially since Subaru springs tend to have relatively few turns at relatively high pitch.
AutoZone lends them for free with a $40 deposit if I remember right. You should also be able to buy them from Sears or from some auto parts stores too.
Or eBay, if you can wait...
http://search.ebay.com/search/search.dl ... compressor*
First know that many of the ebay spring compressors can be purchased for $9.99
Secondly, here are two of the best spring compressors for the money.
http://www.harborfreight.com/cpi/ctaf/D ... mber=43753
http://www.harborfreight.com/cpi/ctaf/D ... mber=47890
stant093 - I'm not sure exactly you mean by how many foot pounds the spring compressed... But stock springs are something like 134 lbs/in and have something like 6 turns. The spring compressors typically fit over 2 turns and compress them by something like 2.5 inches. You typically use two spring compressors on the spring at a time. So each compressor would be handling about 500 pounds of force, maybe, give or take?
Those ciper linked to look really cool... I've never seen them in real life, though; I've just used the type on sale on eBay. The better ones use acme threads. I have done okay with them several times, but I can definitely see the attraction of a compressor that doesn't require you to put any part of your body in the path of a potential runaway spring!
musketeerracing
FYI I found that I only needed the spring compressor for the fronts - the rears you can basically push on far enough to start the threads and then hit with an impact gun.
Definitely need it for the fronts, though. And you get what you pay for with spring compressors. I use one of these: http://www.harborfreight.com/cpi/ctaf/D ... mber=43753 - although as mentioned you have to line it up just right as my Sube anyway has very few winds to the spring.
The cheaper compressor with the two single shafts is like building a house of cards and then trying to sit on it. Except the cards are like razor blades and they jump up in your face. Scary.
ACP
ACP
ACP
www.musketeerracing.com
1991 Legacy SS 5MT Rally car (sold)
1993 Legacy SS 5MT Street car (selling)
1997 Lancer Evo IV RS Rally car (sold)
2006 Lancer Evo IX RS Rally car
2009 Lancer Evo X RS Rally car
1989 240SX SR20 Drift car
musketeerracing
It gives me the shivers just sitting at my desk and thinking about it.
ACP
well i decided to not weld up the spring compressors, and found a good set i can borrow locally.
what struts will fit on a 91 2wd sedan? im curious to know how wide of an array there is for this MY. And will 4wd front struts bolt right up, i mean its an identical setup from a 4wd, only the two front are drive wheels.
The front should be the same, but the rears will be different as they attach to different parts of the rear hub.
greg donovan
TheShocker
- Vendor
Ok I just want to get this straight. I have a 91 Turbo. So the 92 GR-2s will fit the 91 for sure? Will the AGXs for a 92 then also fit?THAWA wrote:That is why they cost more, but there's no reason for them to cost more. The strut is the same. Buying 90/91 rear struts from tirerack is a waste of money.
05 Jeep Liberty CRD turbo diesel
91 Mazda Miata
91 Legacy Sport Sedan 5MT
89 Honda CRX Si turbo
91 Mazda Miata
TheShocker
- Vendor
- quasi-mod-o
Okay, I'm gonna order some GR2's myself. I looked up 92 Legacy GR2's on TireRack and they came up to $58 a piece, I checked the front left and right, and the 4WD rear left and right...
Does that sound right to everybody? If so I'll order them tomorrow...
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
yeah that's pretty good.....I got mine for 70 a piece back in the day....
