If anyone is replacing a clutch or doing transmission work we have a kit to repair the front snout of the transmission (saving big bux) if it has wear and or grooves in it this is the setup. We also have a modified slave cylinder to improve the clutch disengagment point and action at a lower price than dealers.
AL(CO)
al@iwtu.net
Clutch problems ?
Re Clutch Snout
Has anybody ever replaced this part and had success in eliminating the dreaded Clutch Shudder?
Well yes we have had some luck in that department as a few people have insisted that they wanted this part installed at a dealerships. They have gotten it even in warranty repairs although they had to pay for the part. They report that it has cured the problem or helped and it does make the clutch work better. The factory has been in touch with us and even came out to see us about the possibility of authorizing it as a warranty part. Several dealers and service shops are trying it but I can't really claim that this alone will cure the clutch shudder problem as we think there is more than one cause. I do know that I would not think of doing a clutch replacement job on my own car or any other without it because of the wear problem on the snout. We have found the wear on low mileage transmissons and it can only get worse and have had my fill of pulling transmissions for any reason. So we are trying our fixes and also duplicating the latest factory fix to really get to the bottom of the problem and will be including this part with any other item we can come up with.
AL(CO)
al@iwtu.net
AL(CO)
al@iwtu.net
They came out to see us but didn't give any answer as of yet. We made them sign a confidentiality aggreement and we have applied for a patent.
One dealership had an unusuall occurance. The General manager was saying that seeing that it wasn't a Subaru approved part and he didn't think they could use it. The service manager said "If you don't buy it I am going to and I will sell them myself rather than see people shell out $800.00 for a transmission case replacement". (They bought them) I was told that the factory only gives 1.3 hrs for a case replacement and even the mechanics hate the job.
AL(CO)
al@iwtu.net
AL(CO)
al@iwtu.net
For a n/a car or turbo? It will be a bit before we have one for the turbo but we are working on it.
Al(CO)
al@iwtu.net
Al(CO)
al@iwtu.net
Clutch Shudder
I had my MY01 Liberty RX clutch plate, throwout bearing replaced last Thurs (Aust) and the dealer also machined the flywheel. They said there was shiny spots on the old clutch plate.
The clutch also had a squishy feel and noise when it was 2" - 3" from being fully depressed, this too has gone since the replacement.
The car also appears to have more power and better acceleration as if the old clutch was slipping a bit but not enought to enable you to hear or notice any difference or maybe it comes from the ECU being reset
Anyway, I am all
's at the moment.
Anyway, I am all
