FAQs, community and board information.
123c
Posts: 396 Joined: Sat Jan 04, 2003 1:44 am
Post
by 123c » Thu Jun 03, 2004 3:55 pm
Legacy777 wrote: It's called the abs ring. I could look it up when I get home. What year, model, etc car do you have?
1993 Legacy SS
Tone Wheel Front: 26750AA003
[color=red][b]1993 Subaru BC Turbo Legacy (193k miles)
1971 VW Super Beetle
1989 Honda Elite 50
[/color][/b]
123c
Post
by 123c » Wed Jun 09, 2004 9:07 pm
New part number needed, I can't seem to find, even in that nice parts reference book Josh provided, and Subaruparts.com can be a little confusing at times.
I can't seem to find the number for the little rubber boots that go over the slide pins on the brake calipers, one of them has a small tear, so I figure I should replace it, and probally all of them...
1989 Honda Elite 50
[/color][/b]
Posts: 27930 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Thu Jun 10, 2004 1:13 am
You can't buy just the boot, however you can buy a rebuild kit that has the boots, seals and lube
Depending on when your car was made....there's two different #'s
If it was made on or before sept of 92 the # is
26297AA020
If it was made on or after oct of 92 the # is 26297AA021
123c
Post
by 123c » Thu Jun 10, 2004 5:11 pm
Do the rebuild kits also come with the anti-rattle clips?
1989 Honda Elite 50
[/color][/b]
Post
by Legacy777 » Thu Jun 10, 2004 6:12 pm
no.....just the parts to rebuild the caliper
123c
Post
by 123c » Sun Jun 13, 2004 2:14 am
Ok, here's another part I can't seem to find, I am looking for the bushings that go into the Stabilizer Link Assembly. I can't seem to find it, I can only find the Stabilizer Link Assembly, but no bushings for it.
1989 Honda Elite 50
[/color][/b]
eastbaysubaru
Posts: 1312 Joined: Wed Oct 16, 2002 10:44 pm
Post
by eastbaysubaru » Wed Jun 16, 2004 11:54 pm
I hope this is an easy one. I've got a few Grill Clips that are broken. The lower middle clip and the clip attached to the passenger side headlight are both broken. Does anyone have the part number for these clips? TIA.
-Brian
'04 PSM FXT
123c
Post
by 123c » Thu Jun 17, 2004 12:46 am
outer clips: 91017AA010
inner clips: 91059FC090
1989 Honda Elite 50
[/color][/b]
eastbaysubaru
Post
by eastbaysubaru » Thu Jun 17, 2004 5:17 am
Which is which? I need one of the ones that attaches to the headlight (outer?) and one that attaches in the center on the bottom (inner?). Outer and Inner seem like they refer to the top clips as there are four of them. The ones that I need are the ones that the grill slides down onto.
-Brian
'04 PSM FXT
eastbaysubaru
Post
by eastbaysubaru » Thu Jun 17, 2004 10:10 pm
Front wheel bearing:
28016aa011nt
Seals for associated bearings:
28015aa070 (inner?) not sure which is which
28015aa021 (outer?)
-Brian
'04 PSM FXT
Posts: 12517 Joined: Sun Nov 03, 2002 2:13 am
Post
by vrg3 » Thu Jun 17, 2004 10:25 pm
The front wheel bearing should be part number 28016AA011. The inner seal is part number 28015AA021 and the outer seal is part number 28015AA070.
I think you need a snap ring for one or both seals; the snap ring is part number 28035AA010.
eastbaysubaru
Post
by eastbaysubaru » Fri Jun 18, 2004 5:01 am
Thanks for the extremely helpful reply Vikash. The part number for the wheel bearing has been superceded by the part number I listed:
28016AA011NT
-Brian
'04 PSM FXT
Post
by vrg3 » Fri Jun 18, 2004 2:26 pm
Cool.
I didn't see that you had edited your post. (That's what happened, right?)
An odd thing I noticed -- the GD-chassis WRX/RS has the same part numbers except for the inner seal which is part number 28015AA080. I would have expected it to be the same.
eastbaysubaru
Post
by eastbaysubaru » Fri Jun 18, 2004 3:55 pm
Yeah, I edited it as I was calling the local Oakland dealership. They were actually pretty helpful this time and gave me all the associated part numbers that I needed. They didn't tell me about the snap rings though, so thanks!
-Brian
'04 PSM FXT
123c
Post
by 123c » Fri Jun 18, 2004 11:07 pm
As far as I know, there are no snap rings. I just had my bearing pressed last week, and the machine shop didn't say anything about one...
1989 Honda Elite 50
[/color][/b]
ferre
Posts: 7 Joined: Sat Nov 13, 2004 1:36 pm
Post
by ferre » Mon Jan 24, 2005 7:18 am
hi all
i'm wondering if anyone would know where i could get the part number for a JDM 2lt gt legacy auto ECU
or even better would be if anyone knows of a parts list for JDM legacy's
i noticed a similar question posted earlier in this thread but it was from awhile ago so i though i would ask in case there is any upadtes
Post
by Legacy777 » Mon Jan 24, 2005 4:10 pm
Hmm....I don't have any JDM part #'s
There might be someone else.
Have you tried
www.rslibertyclub.org/forums ?
THAWA
Posts: 6829 Joined: Thu Aug 21, 2003 7:44 pm
Post
by THAWA » Wed Apr 20, 2005 7:30 am
Does anyone know the part number for the v8+/USDM STi, Legacy GT/Outback XT, Legacy 2.0GT oil pan. The twin scroll one?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Post
by Legacy777 » Wed Apr 20, 2005 5:41 pm
is it different?
THAWA
Post
by THAWA » Wed Apr 20, 2005 8:38 pm
quite
Post
by Legacy777 » Wed Apr 20, 2005 11:57 pm
how so? and what if any are the benefits....or is it just a fitment issue?
THAWA
Post
by THAWA » Thu Apr 21, 2005 1:04 am
It is shaped to allow the use of twinscroll headers.
dzx
Posts: 2711 Joined: Wed Aug 04, 2004 3:52 am
Post
by dzx » Thu Apr 21, 2005 2:23 am
I remember hearing about twinscroll turbos but i dont remember what subaru's they come on. I do remember that there are quite a few differences in the setup.
///M
'93 Legacy SS - part out
THAWA
Post
by THAWA » Thu Apr 21, 2005 2:30 am
They come on v8+ STi's and Legacy 2.0GT's
Post
by Legacy777 » Thu Apr 21, 2005 3:17 am
None that came in the USA correct?
