Tie Rod End question
123c
Post by 123c »
the is grease leaking out from the top of the joint, but to tears or rips in the rubber, should I replace it while I still have everything taken apart...
[color=red][b]1993 Subaru BC Turbo Legacy (193k miles)
1971 VW Super Beetle
1989 Honda Elite 50
[/color][/b]
petridish38
Post by petridish38 »
Wouldn't hurt.... Do you know when they were last replaced? How much resistance is there when you try to move them around? Are they all loose and nasty? Does it feel like there are any contaminants in there such as dirt?
At the least, if you replaced them they would tighten up your steering a tad. You would have to get an alignment as well, but if you're already getting one, then you might want to go for it.
They might have a good amount of life left in them, but if you're one of those "while i'm in there" people, then I would say depending on how long its been since they have been replaced (if you know), and how they feel when you move them around, you might just want to go ahead and do it. Check your ball joints too...
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
123c
Post by 123c »
I think they are original to the car, so they have 189,600 miles on them. I will probally just put it off for a few months, and replace them when I replace the struts and other suspension components...
1989 Honda Elite 50
[/color][/b]
Post by entirelyturbo »
Just replace them. They're not terribly expensive and take about 10 mins a side to replace. You're replacing struts and stuff, so you're going to get an alignment anyway.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
123c
Post by 123c »
Yup, I am going to replace them probally when I replace my steering rack...
1989 Honda Elite 50
[/color][/b]
