Forester XT hp?
Forester XT hp?
I saw a new commercial for the Forester XT today and it said it had 210 hp. Is this right? I thought they had 250/250 like the new GT.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
210 is claimed. They put about 180 to the ground (30 more WHP than a WRX), so figure they've got more like 260ish.
Made me remember this dyno chart of a forester with a vf22: http://www.subaruforester.com/files/dyno.jpg
MK
MK
1992 BC672 AWD 5MT
Unimpressive. Those numbers can be had with the stock TD05. Now if those numbers were at the wheels, THAT would be impressive.
From the thread it the pic came from it's not bad at all, the dyno wasn't reading that there was a car on it untill ~3k. Here's the thread: http://www.subaruforester.com/viewtopic.php?t=4306
MK
MK
1992 BC672 AWD 5MT
The Dyno pic says "Torque Flywheel" and "Power Corrected" which would lead me to believe that it was measured at the crank (converted from WHP to BHP).
The thread, though, says it's at the wheels. Hmmm...
the XT is really a detuned Sti motor (2.5 liter), that's why the motor is such a torque monster which is what you need in a forester (i have a '98)... peak HP is far less important than the area under the torque/power curves which gives you pull all through the rev range
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
1990 Rover Mini 1000
2004 Forester XT
