It's here.......
It's here.......
Got my tranny, diff, and driveline today!!!
So I'm one step closer to start working on things.
Thanks to Jason for the tranny, diff, and driveline.
Thanks to Richard Buckner for the rebuild.
I need a few more misc parts, but as soon as I get insurance swapped over to tx, I'll start the teardown of the wagon :)
http://www.main.experiencetherave.com:8 ... swapparts/
georryan
Post by georryan »
How much was your rebuild?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
The invoice I have is right around 565. Labor was 250.00.
The total price with freight to me was around 900. He replaced the 5th gear shaft with a used one because the original wasn't going on properly. I'm not sure if that's on this list.
I also don't see syncro's on this list either......
georryan
Post by georryan »
Just trying to figure out what I may be looking at in the future. I need a fourth gear synchro job done eventually. I figure when I change out the clutch and flywheel that might be a good time to do it, but we'll see.
I also have a seal up top that lis leaking a little bit.
2014 Volvo S60 T5
BAC5.2
Post by BAC5.2 »
When I end up doing my tranny, I'm going full MRT setup.
Dogged 1, 2, and 3 with stainless synchros and a twin plate. "Supercharged Subaru? Wait, now Turbo? WTF? Where'd he go, and why are there 4 huge black marks where he WAS!?"
That or save for a JDM non-dccd 6mt with dogged 1, 2 and 3. I'd MUCH rather go that route :).
THAWA
Post by THAWA »
rut-roe Be sure you are 100% sure that driveshaft came from the same car as the tranny. That centerjoint usually means 4eat which = too short. It Should have 3 u-joints instead of 2 u's and a cv type like you've got. but hell it might be different for turbo's. If you'd like though I can measure my 4eat shaft so you can compare :)
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
The driveshaft came from the same car....or so Jason said so. If I get time this weekend, I'll pull all the parts out and check them over real good.
THAWA
Post by THAWA »
well that just might be the case with turbo legacy's, but all the 5mt's I've looked under were 3 u-joints (course none of the ones I looked under were turbos :o
Post by entirelyturbo »
Josh are you going to have the only NA BC Legacy with a hydraulic clutch and a 3.90 LSD? 8)
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
possibly :)
THAWA
Post by THAWA »
You might even have the only NA legacy (subaru too) with a hydro and 3.9 lsd
yeah.....My legacy is quite frankensteined even now without the trans stuff...
THAWA wrote:You might even have the only NA legacy (subaru too) with a hydro and 3.9 lsd
All new Legacies have hydro clutches and the GT's have LSD's (the BE/BH's anyway)...
Well, pull-type clutch, then! :)
THAWA
Post by THAWA »
but are they 3.9?
