I waited till being far enought to give you a little update
So this his how it goes..
All gaps were checked with Plastiguage.. amaisingly, i'm into the stock specs even without any crankshaft rework.
shortblock closed after a lot of problems finding guide-pins
all bolts torqued to specs, with some engine oil on the threads.
Pistons, pins and lock pins installed.. ahhh relief ! hehe
and the finaly assembled shortblock. Looks not pretty good especially with that rusted water-pump wheel, but in real it looks nice.. pics is bad :\ hehe i'll have to sand a little bit that wheel so rust goes away ... (that's the only pump with oil-cooler nipple i have :\ )
If i receive the guide-pins for the heads tomorrow, i'll then install the heads, water passage, maybe oil-pan too. I'll keep you updated.
All other pics, and hirez are at this url :
http://public.fotki.com/morgie/morgie/o ... age_moteur
