ECU Reflash
ECU Reflash
Have any of you computer gurus ever considered the option of a reflash of our current ECU so that it could run with 10-13psi without the aid of a boost controller?
98 LGT
My friend got his 04 GTI reflashed. Pretty much they just took out the old ECU and reprogramed it to different perameters so that it could run more boost with all adjustments already made to compensate for it. Then he just pluged it back in. I think he was around 11psi before. Now he's at about 20-23psi.
98 LGT
ultrasonic
Something like Cobb's AccessPort or AccessECU...
http://cobbtuning.com/wrx/accessport.html
http://cobbtuning.com/wrx/accessecu.html
...a product or solution like this for BC/BF turbos would be really great.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
03 Legacy L Wagon
okay I understand the electrical part, but was wondering how you can run a higher psi than normal without any form of boost control.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Milehi can do it. He said he could do it for a couple hundred bucks to people on this board. Try a PM to him.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
ultrasonic
Sure, the stock boost control solenoid, under command from the ECU, with reflashed parameters. Ought to work.THAWA wrote:so it still uses some kind of boost control?
Someone... crack the code!
-steve-
03 Legacy L Wagon
03 Legacy L Wagon
rsstiboy
the Link ECU uses the stock boost solenoid, I can program mine on the fly! at the moment it spikes to just under 20psi then settles on about 18psi by redline.
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
the cobb accessport is way cool but when i talked to them they said unless they see a bc bf market for it and big time they arent even gonna mess with it. kelly has a leg up with his ecu hes makin for this sort of thing
-jason
The stock ECU can NOT be reflashed. In order to reprogram it, you have to remove the ECU, solder in a socket, flash a new chip with the original rom and reinstall. I only know of one that's been done.
Legacy Central
legacy92ej22t
So would that be considered a piggy-back?
Has anyone ever heard what kinda price tag Kelley's talking about for his engine management?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
free5ty1e
Is there a possibility that a performance shop that does dyno tuning might be able to reflash our ECUs? There's a good one close to me that has a 9 second Supra...I'm gonna ask them about a reflash.
-Chris
91SS 4EAT stock, 200k mi
