Pissy 02 sensor plug
This is probably a stupid question but here goes........How does the O2 sensor plug come apart? I can see that it has a tab that you obviuosly push down, but no go, I dont want to break it. Also, a wire pulled out the back of it, can it be re-inserted?
legacy92ej22t
You have to pull it up, not push it down. Use a small flat head screw driver, stick it in there and turn it sideways, then pull it apart. Hope that helps.
Oh and yes they (the wire) can be reinsterted into the connector but IIRC you need a special tool.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
Hehe, ya no kidding, I seriously have about 8 scars from burning myself when working with the O2 sensor while the turbo/exhaust components are still hot.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
