Timing Belt R/R Procedure
Austin
Post by Austin »
Anyone have a procedure for replacing the timing belt on a 91 ej22t?
This is my first time replacing a timing belt...
91 Turbo Legacy Sedan 5MT
02 Impreza WRX Sedan 5MT
02 Legacy Sedan 5MT
Austin
Post by Austin »
I just found out something really cool...
Whoever last did replace the timing belt didn't exactly know what they were doing either. The hydraulic cylinder for the auto tensioner pulley was still pinned shut. Like they compressed it in a vise to get it into place, pinned it (with a pop rivet pin), then forgot to remove the pin...
Great...
I also found out that cylinders #2 & #4 crankshaft has jumped two teeth.
#1/3 camshaft pulley and the crankshaft both line up with their respective timing marks, but #2/4 camshaft pulley is advanced by two teeth.
Great...
On the bright side, should make more power when I get it back together...
So far I need a new timing belt - old one looks great, but I'll replace it anyway just so I know how old it is - I need two new belt idler pulleys...
I also need to replace the front main seal. How do you do that?
02 Legacy Sedan 5MT
I have eight scans from the factory manuals on the timing belt.
If you want me to email them to you, I can.
totech
Post by totech »
I found this pdf somewhere - I cannot remember where, but I grabbed it then, and kept it for future reference.
Sorry if it belongs to someone, let me know and I will give appropriate credit.
Anyway - here it is - seems quite thorough!
http://www.taberross.com/images/auto/Ft ... eplace.pdf
08 GE - SWP
96 BG - SGP
96 CX - EBP
Austin
Post by Austin »
Josh - thanks, that'd be great. Would you please email them to am@charter.net
Thanks!
02 Legacy Sedan 5MT
Austin
Post by Austin »
totech - thanks for the pdf!
What a guide to use as to whether or not I need to replace any/all of the belt idler pulleys? The two smooth idler pulleys have pretty raspy bearing noise, and won't spin for long... but the toothed idler pulley seems to be in awesome shape.
02 Legacy Sedan 5MT
Post by entirelyturbo »
Austin, check my thread out, I did this a little while ago...
viewtopic.php?t=674
Two teeth off??? The engine must have run terrible!!
If idler pulleys have raspy bearing noise then replace them. Mine spun freely and silently...
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Austin
Post by Austin »
Thanks for the thread subyluvr2212 -
What does the surface of the front oil seal look like once you get the crank toothed gear off? I have a bearing puller at home...
02 Legacy Sedan 5MT
Assuming you have the original oil seal, it is a black rubber o-ring seal that fits around the crank, right into the oil pump (the new updated ones are brown). I managed to get mine out with a flathead screwdriver, but whatever method you use, be very careful not to damage the oil pump or seal seating surface, and put a little oil on your new seal to help install it, I just took a bolt thin enough to gently hammer the new seal in with...
Austin
Post by Austin »
I'm sure they're posted elsewhere... but here are relevant part numbers.
The two prices are list on left and subaruparts.com price on right.
13085AA070 Idler Belt Cp $76.75 $58.48 (toothed idler)
13073AA142 Pt340292 Idler Cp Be $83.35 $63.51 (smooth idler - x2)
800110360 Pt340292 Bolt $1.38 $0.88 (smooth idler bolt - x2)
13028AA102 Timing Belt $59.95 $45.68
806919050 O.ring $2.58 $1.97 (oil pump o-ring)
806733030 Oil Seal $6.42 $4.89 (front crankshaft seal)
21111AA026 Water Pump $83.95 $63.97
21114AA051 Gasket Water Pump $2.55 $1.94
21200AA072 Thermostat $12.25 $9.33
21236AA010 Thermostat Gasket $3.23 $2.46
02 Legacy Sedan 5MT
I have several scans from the factory manuals and chiltons......you can d/l what you want
http://www.main.experiencetherave.com:8 ... ual_scans/
Austin
Post by Austin »
I've looked through the .pdf's... can't find them..
What are the water pump/oil pump bolt torque specs?
02 Legacy Sedan 5MT
Austin
Post by Austin »
Thanks Josh :D
I went through those, but..
Am I just blind? I don't see the water pump & oil pump bolt torque specs listed in there...
02 Legacy Sedan 5MT
I don't know if the torque specs are in there.
Nate S
Post by Nate S »
when I get to my shop tomorrow morn I will see if my online ( cd ) manuals have it and let you know ( if you still need it )
nate
S-Squared Motorsports
Looking for aftermarket parts? Email me
nate@ss-ms.com - www.ss-ms.com
shop # 916 631 7440
92 turbo wagon / 02 wrx sedan
Nate S
Post by Nate S »
ok my online manuals list the following
oil pump bolts at 56 in/lbs or 6.4 Nm
water pump bolts at 85-120 in/lbs or 10-14 Nm
hope this helps..
Nate
shop # 916 631 7440
Austin
Post by Austin »
Thanks a bunch!
02 Legacy Sedan 5MT
