Knock Sensor
Dean Forman
Knock Sensor
Post by Dean Forman »
Hi all,
I did an ECU test today which reveled a failing knock sensor#22 code. I sort of know what the knock sensor does, but not fully. I also do not know where it is located on the engine and if it is an expensive part or not. Funny thing is, the car has never run better, (but the exhaust is smelling a bit toxic!) Maybe I should just leave it alone? Maybe I can find a used one?
Any input would be helpful,
Dean
92 N/A FWD BF
Oh yeah.... my KYBs came in the mail today. Can't wait to install em.
Replace. Under $50. It's like a little microphone on the block that hears preignition. When it detects it (or thinks it does), the ECU cuts timing ... or it's supposed to. I don't believe in coincidences and my knock sensor was bad when my exhaust valve melted.
Anyway, it's on the back of the engine to the middle on the driver's side. It looks like a small black cylinder with a bolt through the top (either 10 or 12 mm) and a wire going to the connectors at the engine/transmission (along with the plugs for the cam and crank sensors). It can be replaced with a socket and an extension in a couple minutes.
you can find pics of the knock sensor in here dean.
http://www.main.experiencetherave.com:8 ... injectors/
btw...welcome to bbs :)
Dean Forman
Thanks guys. I'll look at the sensor tomorrow, now that i know its location, and see if I can coax it into working again or replace it.
Dean
Dean F. (92 Legacy L wagon, 2wd, Auto 95,000mi) (1980 Ford Fiesta- mega-customized!)
Welcome, Dean.
Also, Subaru has redesigned the knock sensor since our cars were sold. The original design is somewhat prone to intermittent failure (tiny cracks appear in the wire from what I understand), so it makes good sense to swap in the redesigned one if you can find the money.
The Subaru part number for the new one is 22060AA031.
