Rough idle when waiting at lights
magicmike
Post by magicmike »
When the car is in park it idles fine (aprox 800rpm) when its in drive and I'm stopped at a light or whatever the rpms drop down to like 5 or 6 hundred and the car feels like its shaking a bit. My civic used to do the same thing when it got up there in mileage. I'm thinking its the o2 sensor. Everything else is new. New air filter, fuel filter, plugs and wires. I tried a search but only found advice on changing all of the things I just described as new. I'm thinking its the o2 but I dont know. What do you all think. its a rebuilt engine so it should be running smooth I thought ;)
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
There's a quick check you can do to see if it's the oxygen sensor. Unplug the sensor, reset the ECU, and see how it does. If the problem persists, it's not the oxygen sensor. :)
Is there a chance that you have a small vacuum leak? You could do the starting fluid check.
Mine does this occasionally.....I think I need to clean up the IAC valve again.
magicmike
Post by magicmike »
do you mean to unplug the sensor and leave it unplugged perminantly? or unplug it, reset the ecu then plug it back in? I'm confused
Thanks,
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
The former. Unplug the connector, reset the ECU, and then drive around to see if the car behaves any better without the sensor.
Post by entirelyturbo »
I say it's nothing more than a Subaru trait. As most of you know, I've replaced damn near everything I possibly can in the hopes of fixing the bumpy idle. I've replaced the IAC valve with a brand-new one, I've swapped throttle bodies, MAFs, this and that.
Fact of the matter is, I've never driven any Subaru at all that had a perfectly smooth idle. Maybe it's just a boxer four trait...
*Formerly DerFahrer*
The last engine I had idled so smooth (but slightly high) you had to put your hand on it to tell it was running. That was up to about 20k before the exhaust valve went.
biggreen96
Post by biggreen96 »
subyluvr2212 wrote:I say it's nothing more than a Subaru trait. As most of you know, I've replaced damn near everything I possibly can in the hopes of fixing the bumpy idle. I've replaced the IAC valve with a brand-new one, I've swapped throttle bodies, MAFs, this and that.
did you change motor mounts?
