Yes, I am swapping out the original 4EAT for a more recent one from the WRX. My reasoning behind it is quite accidental but I lucked out... I think. So, unless the original dimensions of the WRX's dif & tranny are different from ours, I believe my original driveshaft should fit back in.
As for the rear axles- 1/2 shafts I'm unsure if the differential has "in’ zees" or "out’ zees" (you know those little stubs that stick out for lack of better explanation:?), I may have to be creative.
Also,I believe that the WRX TCU electrical connectors (3) are different, at least I think the middle one is from the photos I've seen. I'll be much more informed on all these fitment issues once I receive everything next week.
I'm surprised that, seemingly, no one has done this swap... does that mean I'm foolish
... don't answer, wait 'til I give y'all the full picture, at that point it'll be obvious.
Anyhow, I appreciate all your replies and participation
. Should you have anything else to add, objections or tangible, whatever.. "ga-head... make my day"
Thanks,
Mike
