92 front end on 91
92 front end on 91
I've heard that the two fronts are interchangeable, meaning hood/fenders/lights/grille/bumper. This makes sense, seeing as how its the same chassis, but how about everything except the bumper? The bottom of the headlights is the same, as is the front of the fenders. I've taken front ends off BC/BF's before, and its relatively easy, so naturally I'm thinking, better looking(and working) headlights and corners, and sidemarkers with the better looking 91 bumper. Think it'll work?
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
tris91ricer
- Title Whore
Yeah, i've asked josh about this one, and many people are thinking about it. It has something to do with the length of the hoods, and the hood latch thing, which is in the radiator support, from what i understand, although it didn't make sense that way when i was doing my engine swap.. I think it actually might work, if you want to give it a try. But you have to take the fenders and all that, in order to go facelifted...
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
The hood latch? I don't understand. The latch stays in the same place when you swap hoods, and that does work.
I actually once saw in a junkyard a post-facelift car that had a pre-facelift front end put on it.
tris91ricer
- Title Whore
None of the pieces are the same from prefacelift to post facelift so natural nothing will line up right if you try to mix and match. It's an all or nothing affair. My question to everyone though, has anyone ACTUALLY done this. From what I've noticed it has all been speculation. But I can quite easily see it not working without making some cuts in the headlight area depending on how the headlights are mounted on the 92-94's
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
I removed that car's headlights to look closely because I was curious, and I didn't see anything that looked like that part had been modified... the steel was the same color as the back of the car and I didn't see any welds or anything.
But maybe there was some modification involved.
- quasi-mod-o
Vikash, we know the facelifted hood is shorter, so while the hood latch on the rad support will be in the same position, the ring on the hood might not be.
You'll definitely have to change the hood/fenders/lights/grille/bumper as mentioned, but it wouldn't surprise me if you have to change the rad support as well...
mike, it's like a jigsaw puzzle. you've got a picture placed on it which would be where the hood latch is. The puzzle could be cut in many different ways though the picture stays in the same place, so when you put the puzzle together the picture looks fine. See what I'm saying? Just because the hood is shorter doesnt mean they changed the location of the hood latch. They would have had to change the whole front part of the body if they wanted to keep the hood latch the same distance fromt he front of the hood. That would've been way too much work so they just changed the position of the hood latch in relation tot he distance from the front of the hood. If you're confused be all that suffice to say it will latch fine.
okay. well, got the digital nikon camera, repair manual, tools, jack and stands all ready. called the guy about the '92. will be picking it up later tonight. then tomorrow i'll try the swap.
quick question... the metal piece above the headlights (right behind grill) is bent on the driver side... is this welded on? would it be easier to try and just bend that piece back to its original shape?
I believe that part is part of the frame, yes... So heating it and bending it again might be the way to go. I don't think it has to be perfect; you just need to make sure you can mount and correctly aim the headlights.
