I am dumb founded. I have reset my ecu a bunch of time and I am still getting weird codes. Lets keep in mind the 91 ej22t seems to be running fine. These are the codes 22, 23, 35, 42, 44, 45. The turbo seems a little slugish in second gear but other than that the car is running fine. I would be greatful for in inputs.
No. I have tryed to clear them by using the instructions posted here on this site and I have tryed clearing them by doing a battery diconnect. All six or seven codes come back. Some times its feels like the wastegate is not working. Most time I get a good spool up and some times I don't.
The old one has a grey connector, it was prone to cracking and was oversensitive (would detect something other than knock and pull timing). Replace it with a new sensor from your favorite local dealer, and it should have a white connector on it, telling you that it's updated.
