I know it's obvious, but having a brain fart
dscoobydoo
Post by dscoobydoo »
Ok, I put the AGX's on, and the rear adjustment on the struts is obvious,
BUT HOW THE HELL DO I ADJUST THE FRONTS????
Someone is going to reply and I am going to go DOH!
But it's killing me having this big of a brain fart.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
your struts came with a tiny little screwdriver right? look at the top of the strut shaft.
professor
Post by professor »
they also should have come with the instruction sheet folded up into the little bag that also has the stockers and top nut & washer in it.
A classic funny japanese set of instructions with phrases such as "12 mouth warranty", and the directions for adjusting
if you don't have it I can fax it to you
dscoobydoo
Thanks, I will check tonight. It's snowing here and I did not want the car to suffer and undue hardships- so I drove my truck today
05 GD-STI
00- GF
tris91ricer
Title Whore
Post by tris91ricer »
ooh.. fun, snow!
12 mouth warranty --hahah, that's great!
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
BAC5.2
Post by BAC5.2 »
Small screw driver. Push in on the black, slotted, "button" and turn it. The white dot will line up with a number (1 through 4).
You can adjust all 4 struts in under a minute.
I really like how they set up the whole system. Very easy to adjust and get to.
