After reading all of the posts about crank pulleys I decided to snug up the one on my LSI sedan. Had some trouble with it slipping so I decided to turn the engine backwards (loosen). THE BOLD CAME LOOSE WITH NO EFFORT!!
It was loose the whole time! I couldnt believe it. I found a cheap easy way to tighten it for those of you who dont have alot of tools. Goto Kragen, they have strap wrenches for 9.99. Remove the alternator/PS belt. Wrap the strap wrench around and while keeping it tight rotate the engine until the pipe wrench touches the PS pump Pulley.
The PS pulley will hold and continue to tighten the strap. I was able to get over 150 ft lbs, though I stopped at 150.
Crap! Check your crank pulley! Even if you think its tight
Crank pully
I just replaced mine last week. the bolt was fine/tight but the thing was coming apart! It could have been a di$a$ter.
1993 Turbo Wagon Stock w/turbo back 3"exh, KYB's
that's why you add a little bit of locktite......
I'd like to nominate this for a sticky. this seems to be one of those universal issues like the engine hesitation. I'll check mine tonight even tho I'm selling the legacy. I don't want the crank pulley falling off on anyone.
IggDawg is cool.
-IggDawg
1994 Barcelona Red SVX LSi.
1990 CRX Si (for sale)
-IggDawg
