Cooling fuel for more Horsepower
Brat4by4
Stratified
Post by Brat4by4 »
http://store.summitracing.com/product.a ... htype=ecat
Check this out. Anyone ever try this? Might do some good for you guys with the bigger fuel pumps. Anything that gets you farther away from detonation has to be a good thing.
Sir Yach-o
Post by Sir Yach-o »
But really, how hot does the fuel really get before the injectors? I doubt this does much, but I'm not the expert on fuel delivery.
I'm saving up for my Yugo.
It might get warmed up some by the fuel pump, and by the fuel returning from the engine bay, but...
Warm fuel (to a point) is a good thing, I think. It promotes better vaporization. That product is being sold to prevent vapor lock, not detonation. With modern EFI systems, vapor lock isn't an issue anymore. When the warm fuel does atomize, it still cools the intake charge a good deal because it's so volatile.
DLC
Post by DLC »
A water injection system is what you want, so that you're injecting a liquid that can rapidly absorb the heat in the intake air, making room for more air.
Legacy Central
FG!!
Post by FG!! »
Some Jags had fuel cooling. They say it helps cool piston tops.
92ss, 66bsa thunderbolt, 92miata, 06wrx
