Another pic…
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com
of beats and rhythm" - ME
Throttle Body.....high idle fixed.....mostly ( another pic)
Another pic…
Josh Colombo
ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.35 ... 000239/R=1>
<http://us.adserver.yahoo.com/l?M=226014 ... =705339451>
Josh Colombo
ADVERTISEMENT
Another pic…
Josh Colombo
Josh Colombo
Glad to hear it works Josh I have one older TB around that has that
screw that you mentioned, it didn't do anything when I turned it so it
ended up not being used as it is old and in rough shape. I don't know
what engine your TB came off of I just looked for the best ones that
hadn't been cleaned. It does sound like you may have a vacuum leak
they can be a little hard to find but it could be your IAC valve
leaking air, they will whistle when they leak but they usually don't
leak at normal boost. I am running over 15lbs now and I am going to
relocate the air intake for the IAC valve to a place after the turbo
and before the intercooler to prevent this. I got the idea from a
friend that had his car was on the dyno here Sat. it had 310 hp at the
wheels that means about 370 at the crank.
AL(CO)
--- In BC-BFLegacyWorks@y..., "Josh Colombo" <josh@s...> wrote:
> Another pic...
> Josh
> Josh Colombo
> <mailto:Josh@s...> Josh@s...
Kwick Pick opens locked car doors,
front doors, drawers, briefcases,
padlocks, and more. On sale now!
http://us.click.yahoo.com/ehaLqB/Fg5DAA ... /XoTolB/TM
AL(CO)
> Another pic...
> Josh
> Josh Colombo
Thanks again Al.
I'm goin to play this weekend. I'm outta town all week. I need to set the idle with the IAC a tad higher. But I gotta pick up a more precise tach.
I'll let ya know what I find out.
-----Original Message-----
From: milehial2000 [mailto:acroxford@hypermall.net]
Sent: Mon 6/3/2002 9:49 PM
Cc:
Subject: [BC-BFLegacyWorks] Re: Throttle Body.....high idle fixed.....mostly ( another pic)
AL(CO)
> Another pic...
> Josh
> Josh Colombo
Cc:
AL(CO)
> Another pic...
> Josh
> Josh Colombo
