CEL...problems...
Locked
Brian White
CEL...problems...
Post by Brian White »
Ok, here's my current problem. I get a CEL yesterday
afternoon. It reappears this morning. I went to go
investigate just now and couldn't find the two
connectors that need connecting. The only set of
unplugged connectors that I found were the green ones.
I can't locate any other connectors that A. have only
one wire attached and B. are disconnected. The only
other connector that I found that has one wire
attached is this little pinkish one on the right side
of the steering column. Anyone else have problems
locating this black connector? According to Josh's
site, it's a black connector that has only one wire
attached. HELP!
-Brian
__________________________________________________
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
subbyrs91
CEL...problems...
Post by subbyrs91 »
> attached. HELP!
> -Brian
> Do You Yahoo!?
Brian, don't worry it's there...just tricky to find......
First, get yourself a good torch...Second, lie upside down in the
drivers footwell...get yourself as comfortable as possible...ensure
both hands are free to burrow through the maze of wires around the
steering column...be patient!
Good Luck!!
Kwick Pick opens locked car doors,
front doors, drawers, briefcases,
padlocks, and more. On sale now!
http://us.click.yahoo.com/ehaLqB/Fg5DAA ... /XoTolB/TM
jason grahn
CEL...problems...
Post by jason grahn »
By torch he means flashlight. :)
-Jason
Chat with friends online, try MSN Messenger: http://messenger.msn.com
Josh Colombo
CEL...problems...
Post by Josh Colombo »
Brian,
At first I couldn't find mine either. What I'd suggest doing is
loosenin the two bolts that hold on the TCU (assuming it is there.....if
you have an auto) If you have a manual....it shouldn't be
there......and finding the wires should be easier.....but if it
is.....they could be hiding behind there.
Keep searching....they are back there. Just need to find them.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
-----Original Message-----
Sent: Thursday, June 06, 2002 2:50 PM
Subject: [BC-BFLegacyWorks] CEL...problems...
Ok, here's my current problem. I get a CEL yesterday afternoon. It
reappears this morning. I went to go investigate just now and couldn't
find the two connectors that need connecting. The only set of unplugged
connectors that I found were the green ones. I can't locate any other
connectors that A. have only one wire attached and B. are disconnected.
The only other connector that I found that has one wire attached is this
little pinkish one on the right side of the steering column. Anyone
else have problems locating this black connector? According to Josh's
site, it's a black connector that has only one wire attached. HELP!
-Brian
Do You Yahoo!?
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Locked
