Dave's VF10/TD04
Locked
William D. Robinson
Dave's VF10/TD04
Post by William D. Robinson »
I replaced the stock IHI turbo on my 92 Legacy (USA) sedan with a TD04 from a JDM EJ20. It required a bit of modification of downpipe, so I did a radical exhaust overhaul at the same time. I have no more lag and better top end, but the lag issue may be more due to a less restrictive exhaust. Outlet to throttle body is bigger and it aims horizontally at a coolant connection. You will need a really sharp 90 degree silicone elbow to steer the boost around that fitting.
I would always upgrade my fuel pump and add a rising rate fuel pressure regulator before upgrading a turbo. Fuel supply is the first weak link in EJ22T power upgrades. The symptom is that it has just as much power at half throttle as it does at full throttle.
Bill Robinson
92 Sedan EJ22T
dfullerton
Dave's VF10/TD04
Post by dfullerton »
I have a UK spec RHB 52 uk legacy turbo for sale ! its recon as well. I think its bit bigger than stock US one. make me an offer
----- Original Message -----
From: William D. Robinson <mailto:vultureboy@mindspring.com>
Sent: Tuesday, June 11, 2002 9:11 PM
Subject: [BC-BFLegacyWorks] RE: Dave's VF10/TD04
Bill Robinson
92 Sedan EJ22T
Locked
