ECU code checking
Locked
William D. Robinson
ECU code checking
Post by William D. Robinson »
The bettery dance ECU reset technique takes too long, unprograms your clock and stereo and often just doesn't work. The rolling technique as detailed on Josh's site is the only way to go. Believe me, I have reset my ECU so many times in the last three months, I know what works.
Bill Robinson
ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.35 ... 000239/R=1>
<http://us.adserver.yahoo.com/l?M=226014 ... =564059817>
Josh Colombo
ECU code checking
Post by Josh Colombo »
Here is the only issue with plugging the connectors in.
It will clear the codes from the ECU memory. However it does not "RESET" the ECU.
Try it for yourself. plug the two connectors in, clear the memory, and then disconnect the connectors. Then drive the car. There's no discernable difference in how it drives.
Now try the battery dance. Do the procedure listed on the site, then drive the car. The car will act differently until it picks up more data to learn A/F mixture.
So the connector plugs will clear the memory......however they will not reset it from a fresh point.
-----Original Message-----
From: William D. Robinson [mailto:vultureboy@mindspring.com]
Sent: Thu 6/13/2002 12:55 PM
Cc:
Subject: [BC-BFLegacyWorks] RE: ECU code checking
Bill Robinson
ADVERTISEMENT
georgerbyrne
ECU code checking
Post by georgerbyrne »
Yeah, that's what i thought the situation was. That it just cleared
the codes, but didn't reset it. That's why i was interested in what
wires to use. Essentially i would want to be able to reset it. I am
always doing mods to the car and chopping and changing parts, and i
get sick of having to reset my stereo etc every time :(
And don't worry Josh, your site and Legacy Central are big on my
favourites list, always picking up good info from them ;D
Thanks, George, Australia.
> From: William D. Robinson [mailto:vultureboy@m...]
> To: BC-BFLegacyWorks@y...
> Cc:
> Bill Robinson
> ADVERTISEMENT
<http://rd.yahoo.com/M=226014.2032696.35 ... upweb/S=17
05064983:HM/A=1000239/R=0/*http://ads.x10.com/?
bHlhaG9vaG0xLmRhd=1023991299%
3eM=226014.2032696.3508022.1829184/D=egroupweb/S=1705064983:HM/A=10002
39/R=1>
M=226014.2032696.3508022.1829184/D=egroupmail/S=1705064983:HM/A=100023
9/rand=564059817>
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Will You Find True Love?
Will You Meet the One?
Free Love Reading by phone!
http://us.click.yahoo.com/Deo18C/zDLEAA ... /XoTolB/TM
Rod
ECU code checking
Post by Rod »
i agree also,
rod
----- Original Message -----
From: William D. Robinson <mailto:vultureboy@mindspring.com>
Sent: Friday, June 14, 2002 3:55 AM
Bill Robinson
Josh Colombo
ECU code checking
One thing you can try,
It has been mentioned on another board. There is a fusible link or fuse that cuts power to the ECU, but doesn't mess with the radio stations and such. I can try and find out more info and post what I find.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
Sent: Thursday, June 13, 2002 7:59 PM
Subject: [BC-BFLegacyWorks] Re: ECU code checking
> Cc:
> Bill Robinson
> ADVERTISEMENT
39/R=1>
9/rand=564059817>
limonoah
ECU code checking
Post by limonoah »
Its SBF no. 2, although im not sure if it will do what you want.
Noah
find.
> Josh
> Josh Colombo
> Josh@s... <mailto:Josh@s...>
Locked
