I was getting an o2 sensor error code, so I installed a brand new o2
sensor in the up pipe. I started it up and let it idle for 10 mins or
so, and all seemed fine. Turned it off and back on with no error
code. So i took it for a test drive and i found a dead spot at about
1/4 throttle, i.e. around the 0 mark on my vacuum/boost gauge (from
10in hg - 2 psi). AF gauge says i was running lean during this time.
It almost seems like its stalling, the RPMs to drop slowly and the
shifter shakes, but it doesn't die. Whats going on? any ideas?? I am
really stupefied by this.
Thanks, NOah
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/3PCXaC/PfREAA ... /XoTolB/TM
new oxygen sensor
new oxygen sensor
Have you reset your ECU? The computer stores codes and sometimes affect
performance, drivability if there is one in the memory.
I have the instructions on my site how to reset the ECU. It's in the
notes & tips section, engine related. www.surrealmirage.com/subaru
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
-----Original Message-----
Sent: Friday, June 21, 2002 79 PM
Subject: [BC-BFLegacyWorks] new oxygen sensor
Thanks, NOah
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Risk Free!
Josh Colombo
Thanks, NOah
Risk Free!
new oxygen sensor
Problem solved, i hope. I think my problem was that I didn't have one
of the wires securely connected (silly me trying to save money by
buying the universal kind). But thanks much for the response josh!
affect
the
> Josh Colombo
> Josh@s... <mailto:Josh@s...>
> From: limonoah [mailto:limonoah@h...]
> To: BC-BFLegacyWorks@y...
o2
or
about
time.
am
> Thanks, NOah
Risk Free!
affect
the
> Josh Colombo
o2
or
about
time.
am
> Thanks, NOah
Risk Free!
new oxygen sensor
My oxygen sensor seems to be slowly going (the check engine light
comes on about once a month and the code is the oxygen sensor). I was
wondering how hard it was to replace. I have a 1990 non-turbo Legacy
with an automatic transmission. Thanks.
Risk Free!
Risk Free!
new oxygen sensor
It's pretty easy, just need an open end wrench and unscrew the thing
from the collector in the front. If you have jacks it would make it
easier to get under the car, however you don't really need them. I
changed mine in like 10 min.
Josh Colombo
Sent: Saturday, June 22, 2002 11:15 PM
Subject: [BC-BFLegacyWorks] Re: new oxygen sensor
Risk Free!
Josh Colombo
Risk Free!
new oxygen sensor
Josh,
You guessed what I was thinking (I was wondering if I should approach
it from the bottom or top). I have some car ramps, so I guess I could
drive it up the ramp and replace it.
I have another question for you. I noticed there are two different
oxygen sensors for 1990's. Do you know how I can tell which one I
need to get?
Thanks again.
> Josh Colombo
> From: formview [mailto:yahoo@m...]
was
Legacy
> BC-BFLegacyWorks-unsubscribe@e...
Risk Free!
need to get?
Thanks again.
> Josh Colombo
was
Legacy
Risk Free!
new oxygen sensor
>From the top end you'll need to disconnect the wire and such from the
clips. From the bottom end you'll need to take the sensor out.
The dealer should know.....but the cut off month is July 89. If your
car was made before July of 89 you'll use the cheaper sensor, if your
car was made in July or after, it'll use the more expensive one.
Have the dealer double check the dates, but I'm pretty sure they are
correct. The fact that there is two sensors is one of the reasons I
would recommend just getting one from the dealer, because most of the
aftermarket stuff isn't going to give you two options....
Josh Colombo
Sent: Sunday, June 23, 2002 12 AM
Josh,
need to get?
Thanks again.
> Josh Colombo
was
Legacy
Risk Free!
Josh Colombo
Josh,
need to get?
Thanks again.
> Josh Colombo
was
Legacy
Risk Free!
new oxygen sensor
It's my luck day
The plate on my door says it was manufactured in
6/89. I'll check with the dealter though. Thanks.
the
your
your
the
> Josh
> Josh Colombo
> Josh,
approach
could
> need to get?
> Thanks again.
thing
it
I
> > Josh Colombo
> was
> Legacy
Risk Free!
the
your
your
the
> Josh
> Josh Colombo
> Josh,
approach
could
> need to get?
> Thanks again.
thing
it
I
> > Josh Colombo
> was
> Legacy
Risk Free!
