Hi All: Looking for suggestions on how to hold the main pulley as to
remove the bolt that holds it. First time trying on an auto trans.
Any and all suggestions welcome. Thanks
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/TPvn8A/PfREAA ... /XoTolB/TM
Main Pulley Bolt
Main Pulley Bolt
There is a small little plug thing on the passenger side bell housing of
the tranny. Pull the plug out, and stick a BIG crowbar type screwdriver
down there. You'll need someone to help hold the crowbar thing while
you take the bolt off.
Other option, and prob more correct method is to buy a pulley/pipe chain
wrench which will hold the pulley while you loosen the nut.
When you put the pulley back on, torque the crank pulley bolt to 110
ft/lbs of torque, and apply locktite to the threads of the bolt.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
-----Original Message-----
Sent: Monday, July 08, 2002 5:31 PM
Subject: [BC-BFLegacyWorks] Main Pulley Bolt
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Risk Free!
Josh Colombo
Risk Free!
Main Pulley Bolt
Back behind the intake manifold on the passenger side, there should
be a small hole that will let you see the ring gear for the starter
motor. Jam a beefy screwdriver in there and it won't move. I used
this method to install an UOR Underdrive pulley and it worked great.
to
Risk Free!
to
Risk Free!
