My Paeco long block arrived Thurs. with all the new pumps, idlers, gaskets, etc. Ordered my Magnecor wires & they should arrive next week along with the custom intake, fuel filter and oil pan. Joel @ PDM (in Co.) has been a great help & along with Al`s suggestions, I should be in fat city! Here`s a breakdown as to what I`ve done so far and the next few steps after the engine is running (week of June 9th.) here goes....block is bored .040 over w/ 1/2" stroke-Arias 9:1 forged pistons with thermo coating-chrome moly steel rods-hard chromed crank-retained oil squirters-crank line bore checked-upgraded bolts throughout-copper head gaskets-heads had CCs checked-bronze guides-SS valves and seats-titanium retainers-upgraded valve springs to match torque cam-intake modified to parallel fuel feed with a billet, dual outlet fuel filter + extra port for additional injectors (if needed later)-380cc injectors were cleaned and balanced-turbo MAF to be added to operate injectors w/stock NA ECU-Walbro 255 lph fuel pump-new sending units for both tanks-Vortech RRFPR with stock FPR (for idle-will not be needed once the Unichip is installed)-stock TB (for now-will need more research before this mod is done)-MSD #6212 DIS-2 ignition w/boost timing master and rev control-modified air intake with K&N filter and i/s & o/s of air tubes from filter to TB thermo coated-2.25" up/down pipes with bellmouth and wastegate divider in DP-boost controlled alcohol injection (metanol or denatured) with manual volume control-Blitz turbo timer. Other upgrades include an Optima battery, JMO convertor, TransGo shift kit, upgraded trans cooler and factory filter system. All fluids are Redline synthetic including their water-wetter mixed with distilled water and upgraded anti-freeze (motor will be broken in with dino 10w-30 oil and changed 3 times in the first 1k miles.) After approx. 8k miles, the 10w-40 redline will go back into the crankcase. First mod after running will be another hi-flow cat and straight-thru 2.5" exhaust system. If you`re in the area, I have a Dynomax straight-thru muffler for you that`s in excellent shape. Next, the Unichip that will have drivers for boost, fuel, timing, etc. It`ll have 2 maps that are switchable between 91 octane settings and race gas. Next will be the 550cc injectors tied in with the Unichip install. Finally, I`ll add an IC once my turbo hood is modified for better air flow. BTW, I had reported before that I had a Garrett T20 turbo-wrong! It`s actually a T28 that`s designed for quick spool-up with a 60 AR for top end. It`s good for between 350-400 hp. I`ll keep everyone updated as to how each upgrade has helped and if it was worth the $$$. Sorry for the long post--Almost Running Rod
