Help! Weird engine dying problem! Any Ideas?
douglas vincent
Post by douglas vincent »
Ok, so I picked up a 90 legacy AWD wagon for $300. Had new TOYO touring tires all around. Put new front rotors on, new radiator and fixed the speedo cable. Spent about $350 for that. Not bad. Oh yeah, the finger sized hole in an exhaust valve might have had something to do with the good price.
So I pulled the heads off, had them done and fixed, put a new water pump in while I was at it (About $191 for the head job, $55 water pump and $105 for gasket set), and presto, a great running car. This took about 7 hours total (1/2 and 1/2 two separate days)
OK, so at this point I think, hey, only $1000 total spent. Runs great, handles ok, breaks ok, and even the radio works. What more do I want?
Well, what I want is a car that doesnt have the rev limiter (or so I suspect) kick in when cornering hard WOT (ususally in 2nd) in the right hand direction. The engine just quits pumping fuel (or so I think) because the engine doesnt officially die, it just backs down to idle. You wait a second and bang, off you can go again WOT, unless you are still swinging around the corner, then it gags again and you have to wait for a few seconds before you can stomp the throttle again.
So basically, a -either the rev limiter is getting turned on, b - something is moving from the force of turning and turning off the injectors, c- something I am not thinking off. Remember the car does not die, just stops getting fuel.
Could it be something in the throttle body? just thinking out loud. BTW, nothing obviously loose in the engine bay.
douglas vincent
portland oregon
Brat4by4
Stratified
Post by Brat4by4 »
$191 for a head job :shock: !!! Nevermind.... :oops: :lol:
How much gas do you have in the tank? Long sweeping corners are notorious for starving the fuel pump in some gas tanks (like most Subarus) with a quarter tank or less. If it does this with a full fuel tank... we'll i'd still check the sending unit and all that jazz. It's unlikely to be something wrong in the engine bay or you'd have problems all the time since the fuel is all pressurized and such by then.
Do you have an auto or manual.
To my knowledge, manuals don't have a rev-limiter....or so I haven't heard of one.
The auto's do, and you'll know if you hit rev limiter. Power goes away very dramatically, but it will not go down to idle.
It sounds like you have a fuel delivery issue.
Check the sendors, etc as mentioned, and keep gas above 1/4 tank when driving hard.
Brat4by4
Stratified
Post by Brat4by4 »
Manuals do have a rev limiter. At least the turbos do. You need it there with how fast the tach needle can climb... Not that i know this from personal experience or anything :roll: .
ciper
Post by ciper »
Maybe the turbo pump inside the tank is cracked. Fuel returning from the fuel rails sucks fuel from the other side of the hump to the fuel pump inlet.
paf
Post by paf »
rev limiter on the auto??!
i doubt it... what rpm is it set at??
1990 FWD Legacy Wagon Base
ciper
Post by ciper »
Couldnt you check for the rev limiter by running the car in neutral and pressing the pedal?!
91White-T
Post by 91White-T »
Yes... anything with electronic ignition has a rev limiter!
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
mTk
no title
Post by mTk »
paf wrote:rev limiter on the auto??!
Yes, there most definitely is. The above method is right, put it in neutral (park works too) and floor it. My auto will top out at 6500 every time.
MK
1992 BC672 AWD 5MT
I've revved my auto past 6500 in neutral before.
However I have hit the rev limiter while driving......it sorta freaked me out, cause it had never happened before. Basically the engine revved faster then the electronics in the tranny could shift.
douglas vincent
Well I am hoping, even though this is problematic, that it is fuel starvation when I have less than a full tank. I will find this weekend at PIR (Portland International Raceway) when I do an autocross.
However, I bet that just for kicks, God wont be smilling and it will still be there every time I take a hard right hand corner.
Blach!!!
paf
Post by paf »
my car revs up to at least 7000 before i chiken out and let off
paf
Post by paf »
and well while you drive its not reallty a rev limiter... it just shifts the tranny to the next gear
douglas vincent
99.5% sure it is the fuel pick up. Hard driving with full tank ,not a problem in sight. Get below half tank and hard curves starve and die.
syphon
Post by syphon »
I'm sorry to resurrect this ancient thread, but I was wondering if you ever fixed this problem? My car has the exact same issue.
Anything under a half tank, and the fuel supply will cut out under a hard right corner. Freeway cloverleafs and such are a pain in the ass!
I figured it was a fuel supply issue, but have no idea what to do about it. What did you do?
douglas vincent
Walbro 255 lph fuel pump. Now I can corner on vapors and the car wont stall.
syphon
Post by syphon »
So it was the fuel pump? I'm having this issue, along with serious hesitation problems that refuse to be fixed by any other means. I'm seriously suspected my fuel delivery system is messing up somewhere, but don't know if it's the fuel pump or maybe FPR or something.
