motor mounts
motor mounts
Well, after noticing some definite shaking, I took a look underneath today, and both motor mounts are destroyed. Are those the only two, and how hard is it to change em? Also, would I be better off getting upgraded ones from somewhere (Not many of the stores around here seem to have em)
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
Just replaced mine with ones from an 02 wrx.
I found the driver's side to be much more difficult than the passenger side (yeah, only two mounts on the engine, not including the rod up top).
I'm already planning to get the STI mounts, and it's probably worth it for you to go ahead and get them.
MK
MK
1992 BC672 AWD 5MT
- quasi-mod-o
Check these threads out, since I've been through the motor mount thing already...
viewtopic.php?t=465
This one shows how important motor mounts really are
viewtopic.php?t=571
viewtopic.php?t=465
viewtopic.php?t=571
- quasi-mod-o
subyluvr2212 wrote:Just tighten them down as much as your muscles will allow you too. Those bolts are beefy, it'd be pretty hard to break them...
Not too good of an idead on the bolts that go into the block, it's aluminum and you could very well damage it.
I just tightened them down reasonably well.
MK
1992 BC672 AWD 5MT
